Question about Sole Fitness Sole F85 Treadmill
F85 Treadmill L51 error, The treadmill shuts down
4 Suggested Answers
  • 33 Answers
SOURCE: my sole f63 treadmill shows an elevation error and
pls do re-calibration
Posted on Dec 11, 2010
ercupa190
  • 12223 Answers
SOURCE: F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Dec 01, 2011
ercupa190
  • 12223 Answers
SOURCE: treadmill will incline but not stay up. incline # stays after bed lowers
incline Motor is not working it can be a few different things.
1) may not be any signal from the console which could be a damaged cable(tight the flexible cable from keypanel vs display board)
2) Tight the connector from display board vs lower board ( main motor controller board the console itself has failed.
3) The motor control board may have failed from a worn treadmill belt and deck measure 120VAC input for the board
5) the motor may have burnt out Test try to measure 120VAC.
6) potentiometer geared to the motor adjust it so the console knows what height the incline is at.
7) the gearing can slip, giving the console false information which can cause chassis damage.
Now see the block diagaram that I did , for person like you, for to know how the main motor board has aprox 90% of functions of any treadmills. sincerely. Good luck, G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Dec 07, 2011
What is L51 on York Fitness t202 treadmill
I'd you wish to get some details about treadmill repair then check the following link.
http://electro-medical.blogspot.com/
Jul 21, 2016 | York Exercise & Fitness
Sole F85 treadmill fan and hand controls not working
There may be two problems, however, I would suggest you replace the main display pcb. That will fix the fan problem. If the handle bar switches still do not function replaces the switch and wiring.
Jan 30, 2013 | Sole Fitness Sole F85 Treadmill
F85's "low speed" error
Dear Sir:
1) Lube the deck belt very well, as your instruction manual indicate for maintenance.
2) Try to Run software calibration after you fix it. For easy diagnose and troubleshooting.
3) The elevation motor can be faulty for lack of maintenance too, again Run the software calibration.
Apr 13, 2012 | Sole Fitness Sole F85 Treadmill
We have a Sole treadmill F85 purchased about 3 years ago with lifetime warranty. When my son would do speed workouts (he is a large kid, about 215 lbs), the machine would shut off after running a 5-minute...
DEAR
THIS MODEL IS WEAK FOR HIGH WEIGHT PERSON AND YOUR ROOM IS NOT YOUR PROBLEM BUT YOUR TREADMILL CHOOSE IS YOUR PROBLEM .
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 15, 2017 | Exercise & Fitness
Sole Fitness Sole F85 Treadmill Logo
310 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
