Question about Mtd 22" Yard Machine Push Mower
Choke on lawnmower not working. how to fix it?
Automatic choke wont engage
check to see if the return springs are still attached to the stationary post and the choke lever.
Jul 19, 2014 | Honda HRX217VKA Lawnmower
Etesia lawnmower
Check to see if choke is closing and opening properly, if yes, adjust the carburetor as it appears you are not getting enough fuel flow with the amount of air intake.
Jun 07, 2013 | Garden
Lawnmower won't start. There is no primer bulb,supposed to start on first pull
Do you have fresh gas? Make sure the choke on carb is working, maybe drain the gas out of carb and or clean it out, check for spark
Aug 19, 2012 | Snapper 20 HP Lawn Tractor 2690578
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I have an old Honda Harmony HRM-215 lawnmower. The first time I used it this year it worked fine, now I have to leave the choke on fully just to get it to run. Even after an hour of running, choke must be...
The air filter may be dirty, have a look at these tips for troubleshooting lawnmower startup problems:
http://www.fixya.com/support/r9118692-lawnmower_not_starting
May 25, 2011 | Honda Garden
Choke lever . Can I fix this myself? broke off and
According to the model, maybe JB Weld the choke lever back together and fuel lines are completely replaceable....get 'um at a lawnmower parts/repair shop. They are Tygon lines.
Jun 05, 2010 | Garden
I have a jcb 5.5hp lawnmower, its starts with the choke closed, but as i open it, a begins to stop, it never use to do this, it always ran, when i opened the choke up, fuel is good
the choke should not be engaged when you are running your mower, it is only for starting cold engines and will choke you mower out if you open it up during operation. Only the throttle should be used to increase rpms
May 05, 2010 | Garden
your carburator is dirty inside.the needle and seat need to be replaced.the needle holds back the gas when it's not needed.hope this helped,just let me know................................
Jun 06, 2009 | Garden
Mtd 22" Yard Machine Push Mower Logo
1,129 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
