Question about Whirlpool MH1150XM Convection/Microwave Oven
Mh1150xms-1 has no power at all, breaker is ok don't know if kids did something wrong and i don't know where the fuses are to change them if thats the problem
  • Whirlpool Master
  • 9,047 Answers
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You will need to enter the full model number with no dashes, e.g., MH1150XMS1.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 30, 2010
Whirlpool accuwave oven & hood totally quit
I don't know about the fuse on the stove but check and see if its still plugged in and make sure that the wiring is sound and then go to the breaker box and see if the breaker is tripped. And Most electric appliances have a safety fuse somewhere.
Oct 02, 2012 | Microwave Ovens
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
Whirpool Micro Wave oven turntable not working model MH1150XMS-2
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 21, 2011 | Whirlpool Microwave Ovens
Maytag MMC 5000 ADW built-in microwave...about 10 years old. Fuse blows and circuit breaker pops every couple of months...what causes this? I keep replacing the fuse, but obviously something is wrong. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There is a high draw of power in the high voltage part...probably the capacitor is going bad...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Sep 10, 2010 | Microwave Ovens
Does the rf375pxdw whirlpool range have a fuse or reset button? burners and oven does not work. there is power from the 220 plug into the range and the clock operates but not the 220. I checked circuit...
No reset buttons or fuses. Find the circuit breakers for the unit, it should be a double breaker with at least 40 Amp rating. Push it to the off position HARD (make sure not to pull the breaker out of the panel doing that). Turn it back on. Check voltage in the range power outlet. It should measure 220-250 Volts between the right and left connectors, and 110-125 Volts between the center and each side connectors. If not - problem is in the wiring or breaker. If you get those voltages and the range is still not working - problem is in the range itself. Check for shorted and loose wires.
Dec 18, 2009 | Microwave Ovens
Need help
1. Have you tested the outlet by plugging in something else and confirming that the outlet is good? If another device doesn't work in the outlet, then you have a bad fuse or breaker that powers that circuit in the house.
2. If power is OK, you probably have a bad fuse in the oven. You'll need to unplug the oven and remove the outside cover. Replace the fuse with the EXACT same rating of fuse of the original.
Please get back to me and let me know what you find.
- Jim
Feb 12, 2008 | Westinghouse WST3504 Microwave Oven
Maytag Microwave Power Outage - Model MMV5000BAB
Found this under GE instead of Maytag, but can answer for you here.
It may be the internal fuse, but more likely it is the thermostat on the magnetron.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 21, 2007 | GE JVM1190SY/WY/AY/BY Microwave Oven
Whirlpool MH1150XM Convection/Microwave Oven Logo
184 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
