Cannot turn on closed caption. no cc button on tv remote. can use cable remote but it says the cc is on when it isn't. the tv remote display indicates it is off. I am hearing impaired and need the cc desparately.
Hi there
Basically,
you can try to access the MENU of your tv with or without your remote,
but as to make things easier, try o access the MENU and look for the
close captioning options there using your remote. you may see it as turned OFF and try
to switch it to ON.
however, you may not be able to see all shows and dvds with caption...
since your problem indicates that you need closed captions on your tv and you cant seem to operate it, please download Jaime867 post about the user manual.
Closed captions and Digital closed captions are found in Page 37 in the user manual...
again, hope you'll be able to see the closed caption soon.
thanks for using fixya.
turning on the closed caption isn't that hard. you just have to select it and press enter or in some other cases, select the closed caption and either push up or down on the remote.
have you tried changing the batteries of the remote?
really... ok. seems like the remote has not helped you at all... this will go down to the show you want to have captions.. does the show or dvd support captions? usually some shows have captions automatically...
so it seems like the captions really is missing... has anyone else touched the remote either than you?
I meant turning it off..sorry..
Try to setup close caption as per instructions on page # 38 of the user manual.
User manual.
You can probably turn it on the the TV's menu using the remote.
What kind of TV signal are you using, satellite, cable, over the air, digital?
Can you provide the exact model of your TV? Thanks.
How is your cable box connected to the TV? I can't seem to get CC from my Satelite box to my TV when plugged in using an S-Video cable. Some set-top boxes and cable combinations just don't seem to work depending on the set-up.
How is your sat box connected to your tv?
What kind of cable connection do you use between your TV and the satelite box?
Does your cable company support CC?
Its in the TV Setup. The Cable box will output the Closed Captioning on
Line 20 or 21 of the Picture - this is just at the top of the TV
Picture where you can't see it. The TV Menu should have a choice of
closed Captioning like CC1, Teletext, etc. and one of them should be
selected. After exiting the menu, you should start seeing Closed
Captioning
on the tv.
I can access the menu but don't know how to turn the closed caption on. When I select my choices it says press enter, return and menu and that does nothing.
new batteries were put in. Did press select, enter all the things I was told to do. Have read pages 37 and 38 of manual and they don't help me.
The shows that support closed caption say CC but no closed caption appears. As I daid I can go through my cable remote to set captions on and it says they are on but they do not show up on the TV. On page 37 of the manual it indicates a CC button on the remote. Mine does not have that button but I can access the CC menu through the TV menu.
Yes it does. I always watched on my other TV set.
still waiting for a reply.
how do I program closed caption
