Question about Dacor Epicure ESG366 Gas Cooktop
10-12 year old dacor 4 burner epicure cooktop --left front burner
It emits one spark as the knob is turned, but the spark doen't continue by the time the gas is on. The other 3 burners work fine
  • Dacor Master
  • 43,501 Answers
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 18, 2010
R rear burner not sparking
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
Dacor sgm304s, Ignitor constantly snapping.
under burner control knob broken plastic cam that operates switch.
Sep 07, 2009 | Dacor Preference SGM304 Gas Cooktop
Viking Gas Burner issue?
is this a sealed burner unit? if so the burner base (the heavy brass part under the burner cap) has to be sitting just right. you will notice that it has holes around the the sides make sure that where your ignitor sparks to it that it aligns with the lowest hole on the burner base. if you have a great flame all around the burner after checking what i mentioned i would replace the spark module. if it continues to drive you crazy with the noise - just unplug it. the burners will continue working fine without power.
Dec 23, 2008 | Viking 42 in. Professional Series...
Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Nov 14, 2008 | Cooktops
Dacor SGG365 one burner control won't cause spark
your problem is most likely the spark switch, but it could be you spark module but that is highly unlikely
Oct 22, 2008 | Cooktops
DCS range igniter won't stop
Hey all ... I just had a repairman fix my DCS cooktop that was doing the same thing ... ignitor problem. He replaced it and it's good as new. (Cleaning also did NOT work for me.) It cost me $216 for the repair. If you can find the part, it's pretty easy to replace. Just take off the front knobs (be careful as there is a 'ring' inside the neck of the knob) and unscrew the front. You will need a special screwdriver - looks like a star - but just snip the plastic straps holding the original ignitor in place and put the new one on the same way as the old one. You should be good as new. REMEMBER TO TURN OFF THE BREAKER!!! I can't imagine it would take more than an hour (tops) 'cause it looked pretty easy.
Sep 01, 2008 | Cooktops
Dacor cooktop ignition problem
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
May 27, 2008 | Dacor Preference SGM304 Gas Cooktop
Jenn-Air Gas Cooktop Model CVGX2423
you will need to contact your certified local service tech.you might have a distributor problem at yor ignitor box.if the problem is not with your ignitors.
Jun 30, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Dacor Epicure ESG366 Gas Cooktop Logo
311 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
