Question about E-Machines W4885 PC Desktop
I have no sound at all. i dont even have the sound speaker in the bottom right corner.
  • 973 Answers
Try to reinstall the driver for your Sound Card.
Posted on May 29, 2010
No suround sound from my pioneer vsxd510
You have to use the Audio Deck or something like that, a software that is provided with your sound drivers. I had VIA sound drivers & I was provided with VIA HDeck (or something like that) I used it to fill sound into the rear speakers without plugging any extra Jack (only the green one)
You can also do this, right click on the volume button on the bottom left corner. Click on Playback Devices > Speakers
click on the Configure button on the bottom left corner of the dialog.
Choose your audio configuration.
Stereo ( 2 Speakers)
Surround (more than 2 Speakers)
Hope this helps.
Jul 07, 2013 | Audio Players & Recorders
The speakers are on but the sounds not working
1.On the bottom right corner of your screen,please right click on the speaker icon
2. Select on Sounds
3. Click on Playback
4. Select on speaker then on the bottom click on Seet as default.
Apr 14, 2011 | Harman Kardon Audio Players & Recorders
I dont have sound on my laptop and i used to
Assuming this is a pc laptop: check the sound settings in Windows control panel. Also check the volume settings in the system tray (the speaker icon in the box at the bottom right corner of the screen. The volume may be turned down or muted.
Mar 08, 2011 | Office Equipment & Supplies
I dont have any sound, I got a message bottom right corner when I click on speaker icon "No Audio Output Device is installed" I think I need drivers for X-220 speakers, I can't find them...
You don't need a driver for the speakers, but a driver for the sound card installed inside your computer. If the computer came with that sound card then you can find the proper driver from the manyfacturer website -> Support section.
Sound drivers need to be reinstalled sometimes after iTunes updates or video game installs.
Mar 02, 2011 | Logitech X-220 Computer Speakers
What if in the bottom right corner of my screen there isn't a speaker, does that mean i have to install my headphones?
Go to your control panel window and open you Sounds and Audio Devices. There should be a box to check there that will show up the speaker icon down by your clock.
Best of luck..
Nov 18, 2010 | Dell Dimension 2400 PC Desktop
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
I get no sound from my speakers. There's an x over my speakers in the bottom right corner
Try going into device manager
click start
then control panel
then system
they hardware
then device manager
if there is a yellow !mark next to sound then use the properties tab to reinstall the the driver
even is there is no yellow !mark update or re-install the drivers
Hope this helps
Dec 22, 2009 | Gateway E-2000 PC Desktop
Hp 6720s speakers not workig
go to speaker icon in bottom corner of screen, right click , go to properties, make sure speakers are enabled and volume turned up and speakers are set to default
Aug 27, 2009 | HP Compaq 6720s PC Notebook
No sounds
Hey,
Few things you can check...
make sure speaker are turned on and volume is turned up or half.
make sure speakers are not set to mute, bottom right corner of yoru screen there should be a speaker icon, double click to open it and make sure noting is muted.
it should look like this:
Feb 22, 2009 | E-Machines eMachines Desktop PC
Hardly any sound.
hi.
In the bottom right hand corner of screen their is a picture of a speaker right click on this with the mouse it will say open volume control and that lets you adjust the volume if this still dont affect the volume then right click again then click properties then if your using external speakers then click on this and you can then adjust the volume of speakers if this still dot work then your sound card could need replacing.
If your only using the speaker in the base then the volume setting will alter this if your using external speakers then the properties will alter this
Let me know how you get on ok
Apr 22, 2008 | Computers & Internet
E-Machines W4885 PC Desktop Logo
60 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
