Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Stalling I had my mower serviced and every since I got it back it keeps stalling out. It will run fine for a while then just stall. I let it set a few moments and it will start up again. It seems the longer I let it set between starts the longer it will then run. It has a new air filter, oil change and so forth. I have had two people look at it. The first said I had bad gas, but I am still having the problem. Can I put carb cleaner in it?
    Problem Solver:
  • 11 Answers
The coil might be breaking down and after cooling down fires until it gets warm again
Posted on May 31, 2010
JD 757 engine stalls and dies when going downhill tilted to the left.
You may have trash in your tank. Check your fuel cap vent too
Jul 16, 2015 | Garden
1991 ford van keeps stalling fuel pumps have been replaced
At what point does it stall? Does it run for a few moments before stalling? If so, it could be a faulty IAC (Idle Air Control).
Oct 12, 2014 | 1991 Ford F150
Have oc60 diesel eng runs for a while then drops in revs sometime picks back up somtimes stalls then restart
Possible low coolant in AC unit. Sounds like the comressor (A/C) is putting a load on the engine when the the coolant is returning to be compressed after it becomes saturated. Possible air dryer or A/C condensor problem, also.
Apr 17, 2014 | Garden
The motor sputters and almost stalls have to use choke to keep it running.
sounds like the flowt is sticking in the carb and it need a carb rebuild kit
Jul 18, 2013 | Garden
Engine runs but stalls when engaged
This sounds like a micro switch, or relay issue, it is not stalling it is being switched off, if there are some relays on the back of the bulk head replace them, they are just a push fit.
Feb 26, 2012 | Garden
MY mower runs fine for about 5-10 minutes than it kills. If you let it set a few minutes it will crank again. Ithought it might be the coil, but when it kills it's still fires
I have had a problem where the gas cap vent hole is plugged up. The mower runs for a while then stalls.
Try removing the cap for 15 minutes and see if it helps.
Gary
Feb 18, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Craftsman 7.0 HP Briggs & Stratton mower stalling
Check the muffler, if the muffler is clogged it could cause overheating of the engine, and could keep the engine from getting the necessary fuel-gas mixture.
Aug 09, 2009 | Garden
2305 tractor keeps stalling out
Hello eireannachcr:
>>Check All the Fuel Connections and Make Sure they are Tight.
>>From Your Description it Sounds like a Loose Fitting or a Bad Compression Washer.
>>A Bad Compression Washer or Loose Fitting will Allow the Fuel to Drain Backwards (sometimes it takes setting for a few days for the Fuel to Bleed Back) when the Engine is Not Running. Once the Engine is Started, it Runs Correctly Until the Air Pocket in the Fuel Gets to the Injector Pump and then the Engine Stalls. The Fuel Behind the Pocket Keeps the Pump and Lines Primed so the Engine will Restart without Bleeding Any Air from the Fuel System.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Apr 10, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
258 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
