Question about Philips 42PF9630A 42 in. Plasma Television
42 inch colored lines on top,If that is the problem is it better off buying a new tv or should i spend the money to fix it
    Scholar:
  • 72 Answers
Its gonna be cheaper for u to buy a new TV than buy a replacement panel if your looking to buy one I highly doubt you will be able to find one under $1500 and thats not including the shipping charge for a panel that weights 80 lbs. Best bet is too buy a new TV.
Posted on Apr 21, 2008
  • James Peters
    James Peters May 08, 2008
    Forgot to ask is the colored lines running vertical or parallel ? defect may be fixable.
Picture freezes
needs a new bulb or ballast check the back of tv for dirt dust and that the fan is working use dusters on vent hole dust blocking venting hole will over heating screen tube. you may want to look into too trading ur tv in and getting a better one... like the led tv i thinks best buy will pay you so much for yours and add that on to a brand new one with new warranty and better options wifi ,bluetooth 2040k-4000k by the time u spend the money on the bulb labor couple dollers more and you get a better one and not just a warranty on the bulb hope this helps
Dec 04, 2014 | Vizio E422VL 42 in. LCD HDTV
I have samsung plasma tv 42" ps42c7s,have sound but dark ,no picture
Hi friend,,,
welcome to fixya
Commonly for Plasma tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Samsung SPN4235 42 in. Plasma HDTV
I have a 42" Samsung Plasma. We have had it two years so the warranty just ran out. We have a half inch red line down the left side of the screen. Also, when the screen should be black, there are hints of...
ONE OF TWO THINGS, THE LINE COULD POSSIBLY BE FIXED WITH A SCAN BOARD, BUT NOT LIKELY, PROBABLY NEEDS A SCREEN REPLACED, THE OTHER RED STUFF CAN BE FIXED WITH A X-BOARD REPLACEMENT, BETTER OFF TO BUY A NEW TV
Dec 30, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Blue vertical line thru picture
It is called "Thin vertical lines" and change colors depending on the background color.
It is fixable but there are several components that can show this sympton.
You will need a tech to fix it in order to save money (because you do not want to buy a board you dont know if will fix it).
Possible Solutions:
Replace Timer Control Board, if it is not fixed
Replace Sustain Board.
One of those boards needs to be replaced and I wrote the most likely first.
May 27, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Sylvania 6842PE 42 inch Plasma Fuzzy picture and horizontal Lines
USUALLY THIS PROBLEM IS CAUSED BY A DEFECTIVE X OR Y SUSTAIN BOARD. ESTIMATE BETWEEN $300- $700
Apr 03, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Jan 27, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
I have a 42 inches LCD TV and my son threw a hard object to it. It has lines from top to bottom and I want to know if it is fixable or not. Thanks, Claudia.
I'm sorry to be the one to tell you that once the screen is broken, is better to buy a new TV because the repair might exceed the price of a new one.
Sorry.
Aug 16, 2008 | Televison & Video
Plasma tv repair question
Thin lines down center of ESA 42"plasma tv, about 1 pixel wide each, about 3/4" to either outside line
Started as 1 then 4 over 4 months
Aug 10, 2008 | Televison & Video
PANASONIC 42" PLASMA TV MODEL TH42PX60U
yes it will be expensive because you will need a new pcb
Jul 16, 2008 | Panasonic TH-42PX60U Television
Display problem for magnavox 42" model 42mf230a/37
first make sure its not an input problem or from an external source.Disconnect all inputs and see if lines are present with no inputs to tv.if lines affect menu and or ON SCREEN DISPAY (top) there is a good chance (SSB) board could be bad .I would start with this board first ,lvds cable (second) and last the logic board (comes only with new LCD)
Jun 23, 2008 | Televison & Video
Philips 42PF9630A 42 in. Plasma Television Logo
83 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
