You can try followings:
- Clean the bobbin case.
- Be sure that there's no thread stuck anywhere.
- Check the housing that the bobbin and bobbin case sits in and look inside that something stuck.
- Oil the balance wheel (hand wheel) and let the oil soak in for a few days.
Hope this helps.
i got the handwheel to rotate now the take-up lever is not moving up and down
Did you insert the new needle correctly?
Check the needle. (Bent, dull, incorrect or inserted
wrong?)
Check the bobbin case, hook, needle plate, etc.
You know that the sewing machines thread in the following sequence. Tension, take-up lever, needle.
Adjust the bobbin tension. The bobbin thread should always make a 180 degree bend before coming through the tension spring. If the thread pulls out to the left, the bobbin will turn clockwise. It will turn counterclockwise if the thread pulls right. Not real important, but can cause some problems.
Hope this helps.
it looks like the stop motion knob is suppose to move the the needle up & down?
Did you try loosening and then tightening the stop motion knob or handwheel tensioner knob?
Is there any oil causing the slippage and keeping the handwheel securing knob from tightening?
i have had this sewing machine for 30 years and this is the first problem i have had! i can see with the top off that the shaft is not moving.
If the ''stop motion knob'' doesn't move the needle up and down, you should adjust the screw in the stop motion knob.
As you know, there should be a "set screw" in the hand wheel. The set screw is usually locked down tight to keep the hand wheel from spinning freely. I f you can run the machine slowly and hold the hand wheel in one place but the machine continues running, then you do need to replace the "set screw". If you replace it you will find that you can offset some of the machines vibration by where you lock the wheel down. You have to try to adjust that.
hope this helps.
Hi Terri,
If it doesn't help I will pass this problem to another FixYa expert to find a solution for you.
Good luck.
Regards.
i already tried the set screw adjustment. there is no change where ever i have that set. i dont remember but is the handwheel suppose to be turning while the machine is running?
Hi Terri,
Yes, the handwheel suppose to be turning while the machine is running.
If you adjust the screw, it should work.
Hope this helps.
The needle and hand wheel aren't supposed to move at all when in bobbin-winding mode.
Waiting your comments.
Best wishes.
the needle doesnt move. when i am bobbin winding the handwheel is rotating
If it is in bobbin-winding mode then you should tighten it to work in sewing mode.
Then the needle and the hand wheel should work (both the hand wheel and the needle should move).
Hope this helps.
Sorry, when you are bobbin winding the handwheel also rotates faster. You are right.
But in sewing mode it also rotates. Tighten it.
it appears to be in bobbin winding mode no matter what adjustments i make to the handweel or the stop motion knob
Did you checked pulley screw, located at the bottom right of the machine, which links the sewing machine motor and the circular belt.
Because of the loose screw, the belt may not move. You may try to tighten the screw if it is not.
the belts are turning. it is not engaging the rod inside the top
It seems to be in bobbing winding mode.
If you have tightened the clutch knob as shown in the picture below, it should work.
If you have manual you may check its sewing mode.
good afternoon... the needle does not go up and down
have you given upo on me? onthe 2nd i sent a message saying the needle does not move. i havent hears back from anyone
Well,stuck up hand wheel, is due to mechanical obstruction inside machine,bushing on shafting need to oil,and on handwheel bushing near clutch there is oil port there. since hand wheel are connected to cam shaft with set of gears and pulley is coupled to motor pulley,and other linkage under bobbins,shuttle race etc,broken gears are most common causes of stuck up handwheel,we can consider also the brush carbon,when worn out and damage the rotor commutator brush.if you can open the cover of motor below side of handwheel,you can see the pulley and motor assembly.also on top of machine there an opening to see the top gear assembly,this should be done by service technician.try to bring to nearest service center if still under warranty claim this for lesser maintenance cost.
Hope I helped with the repair of your problem. An Accept from you is how I get paid. And a positive feed back tells me how I did with the repair.
