Question about Sony 1Gb Memory Stick for Playstation Portable
Creative Zen 5V malfunction
While recharging on a pc, I got a message that Zen had malfunctioned. Zen won't turn on or reboot with pin. PC thinks that Zen is disconnected even when it is not
  • MrsPia Apr 13, 2008
    Help! My Zen V will NOT turn on unless I have it plugged into the computer. Otherwise it shuts down and I'm not able to switch it back on again (until I can plug it back in the computer).
  • 65 Answers
To OregonD: Time to buy another one! Yours has burned out! Or send it in for Free Testing.
To MrsPia: Download the firmware onto your PC from www.Creative.com, then plug in your Zen and load the firmware.
Posted on Jun 12, 2008
SOURCE:
My zen mosaic wont connect to my computer so i cant really do anything with it... I need mass help!!!
Please the driver of your Zen camera on PC for malfunction. You can download the driver at this website : www.mycreativefansite.com/.../creative-zen-mozaic-driver-software.html
After installation done, paired them with firewire / usb cable. It should work now.
Regards, Jay
Feb 01, 2011 | Cameras
Dp-01fx tascam
Since the unit powers up and displays an error message it means that the power supply is working to some extent. The hard drive is probably malfunctioning and needs to be replaced. The DP-01 I have uses an 40 pin IDE 3.5" hard drive so finding a replacement should be easy unless it needs special formatting like TIVO drives.
As for the first solution - why do you think a PC hard drive needs -5v? The PC drive power connector has four pins - two grounds, 5v and 12v.
Mar 30, 2009 | Tascam DP01FX All-In-One Recording Package...
Comp will not recognize Zen Sleek Photo, it says it malfunctioned
I had the same problem. I took all my router ports off and connected just my creative vision and it worked. System was over loaded.
Feb 22, 2009 | Creative Labs ZEN SLEEK MP3 Player
My creative zen vision w is not seen by pc says usb malfuntion wont regonise
I had the same problem. not the USB or PC, but the player. I think you might need to reboot your player. Power on, holding the switch in the on position, and get a safety pin/paper clip and hit the reset button, beside the power docking input. It will give you a series of options, of which I found the Reboot to work.
Feb 19, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen m vision won't start up,
You tried these yet?
Reset, Format or Clean Up a Zen Vision:M
If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
Press on the Menu/Back button on your player, and select System, and then Reset.
To Format or Clean Up Zen Vision:M
1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off.
If the battery is too low, charge the battery fully before continuing
2. Slide the Power switch towards the Power icon and hold the switch in the Power On position.
3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
4. Release the Power switch when the Creative logo appears. The Recovery Mode appears:
* Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
* Format All (Formats the players hard disk - Note: all contents will be lost)
* Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
* Reboot (Reboots the device).
5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
http://dmzweb4.europe.creative.com/...com:80,Case=obj(14048),Kb=ww_english_add
pls rate it, thanks
Nov 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
Recovery Mode
Hi! I think you should try this (i've already tried it and it works):
1- Unplug your Zen from your Computer.
2-Turn off your Zen (if you can't do it, press the "Reset" button)
3- BEFORE turning on your Zen, press your "Play" button and hold it while you turn on.
4-When a format menu appears, select the "Format All" option (you'll loose all your Zen data).
5-When the format menu reapears, select the "Reboot" option and listo! You have your Zen as new and should not have problem. Good luck!
Aug 16, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Zen Touch stuck in "recovery mode"
Have you tried to load the firmware? First you'll need to download the firmware to your PC from Creative's website: Click here. After you've downloaded it, connect your Zen via USB to your PC and open the firmware icon, then click "Upgrade."
For more detailed instructions on how to troubleshoot your Zen, click here
Jun 03, 2008 | Creative Labs Zen Touch MP3 Player
Malfunction
remove the usb drivers from the pc and then reboot and let windows reinstall the drivers, you can also try the usb ports on the back of the pc since they have more power.
http://serviceman.site88.net/
Apr 04, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Zen Vision M
If you reset it and it goes back to just the zen screen, then I had this problem once too. You need to go to recovery mode (which is still possible).
  2. Slide the Power switch towards the Power icon vision_m_reset.jpgand hold the switch in the Power On position.
It will display the following options.
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.Here's the link to the site where I got the info from. (it's another forum). Good luck!
http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=151527#M151527
Jan 26, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs Zen MicroPhoto (8GB) possible faulty USB Cable ????
When I had that problem on my Zen I un-installed all the software and rebooted my system and reloaded the software. Not sure why it worked but it did.
Nov 13, 2006 | Creative Labs Zen MicroPhoto MP3 Player
Sony 1Gb Memory Stick for Playstation Portable Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
