Question about Praktica DCZ Digital Camera
Red lights says busy, camera wont turn on,,,,,,,,,,,
  • 1,170 Answers
The problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera.
Here is a fix :
Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper).
Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera.
This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced.
Posted on May 29, 2010
Camera wont switch on praktica dcz 8 lm busy light comes on 3 seconds then off and nothing after that
took the memory card out and then turn on the camera. Now see the busy keep coming or its gone. If not showing busy any more then format the memory card and then try to turn on the camera with inserting the memory card. Thanks.
May 23, 2012 | Praktica SlimPix Digital Camera
My camera wont turn on after being charged all night and day. i checked it repeatedly to see if it was done charging and all i got was a blinking red light the whole time. it wont turn on!
The battery itself could have gone bad. If the cells within the battery are damaged, it can refuse to charge or power the camera, which would explain the blinking red light.
You'd need to purchase a replacement lithium ion battery.
Mar 12, 2011 | Vivitar ViviCam X029 Digital Camera
Vivitar 8010 camera wont turn on, but has power, red light is on.
I suspect you battery has died,this happened to me the other month.
Easily fixed by buying a new battery, got mine off Ebay £7.99
May 05, 2010 | Vivitar ViviCam 3915 Digital Camera
IT WORKS NOT
Red light busy implies.. its memory access signal.
Its not a problem. What happens after that. I guess it should be fine.
Sep 08, 2009 | Cameras
Red light blinks but nothing happens
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jul 02, 2009 | Olympus FE-310 Digital Camera
I try to turn on camera and first I get green light then red blin
i try to turn the camera...but it seems that hangup,,,,the lights green it blinks blinks,,,,and theres a circle on scren.....i have lotsof pic there that is very important for school...was it gone?waht can i do so that my pic wont lost?pls help..
Apr 10, 2009 | Cameras
NV3 Camera - won't turn on or charge
have been having the same problem. Just pulled the lead out straight and stretched it and now it is charging red light on constantly. May have been a kink in the lead?
Jun 24, 2008 | Samsung NV3 Digital Camera
The battery wont charge
i had the same problem.
if your battery light is blinking a red light then you should call up casio's technical support and they'll send you a new one within 2-5 business days:)
call 1-800-435-7732 for technical support! :)
Apr 01, 2008 | Casio Exilim EX-Z77 Digital Camera
Polaroid A700 digital camera
my batteries are good but the camera just wont turn on at all
Jan 30, 2008 | Polaroid a300 Digital Camera
Praktica DCZ Digital Camera Logo
129 people viewed this question
Top Praktica Cameras Experts
Are you a Praktica Camera Expert? Answer questions, earn points and help others
