Question about Philips Magnavox MWR10D6 DVD Recorder
Error number e 4 54037380. wont record to any disc at all
SOURCE: Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
Posted on Jun 24, 2008
SOURCE: Funai DRV-B2737 Error message
Try using old-fashioned 2x DVD-RW discs, eg the cheap ones from Datawrite.
This seems to work in my machine MOST of the time.
Posted on Sep 12, 2008
  • 127 Answers
SOURCE: It wont finalize disc just says disc error
Sounds like a duff (dirty or scratched) disc. Try another one.
Posted on Jul 08, 2009
  • 4 Answers
SOURCE: recording error E4 54037380
This seems to be a common problem on all DVD players.
If a DVD Lens cleaner (with brushes) fails to fix the problem, then it could be that you have
grease particles on the lens. Do the following:
Note. If unit is still under warranty, you may nullify this by opening unit up
You will need:
Screwdrivers as necessary
Cotton Bud sticks (also known as Q-tips)
Isoproponal/Isopropyl Alcohol (small bottle comes with some CD/DVD cleaners)
Compressed Air cannister/aerosol
1. After disconnecting unit, leave standing for 15 minutes
2. Unscrew lid and remove
3. Carefully remove DVD lens cover
4. Blast whole area with compressed air to remove dust
5. Dip one end of cotton bud in Isoproponal, and very carefully wipe DVD lens (just one wipe
should do.)
6. Now wipe lens with dry end of cotton bud, and leave a few seconds to dry
7. Carefully replace DVD lens cover (watch out for ribbon cables)
8. Replace Lid
9. Reconnect, switch on and test
After I'd tried every other way possible, this method finally worked for me!
Posted on Nov 11, 2009
SOURCE: sv2000 - WV20V6 - how to troubleshoot error E 4 54037380
I have the SV2000 and also got the e4 error. It turns out I tried to program it to record over 3 hours in LP mode. Unfortunately LP mode is only good for 3 hours max. This caused my error during the recording.
Posted on Jan 19, 2010
Device will not play previously recorded discs or record new info,but will play shop bought discs.on occasions it will display disc error. i am using new discs.
I Have had this same problem with DVD recorders. They sometimes will not play disc that were recorded on another player, you have to play these on the recorder that you used to make the recording. When recording you must finalize the discs to get them to play in other recorders, if they aren't finalized then the dvd wont recognize them as being recorded, there is no starting point set on the disc for the laser to pick up on. I have also ran into discs bought at the store that were not any good and I couldn't record on them, or when I did I would get the disc error message also. Try another brand of disc,say Memorex or Soney amd see if these will work, make sure they are compatible with the player, and they are the correct format for your player. There are 2 types DVD -R and DVD + R the + R work better on a wider range of players.
Nov 25, 2010 | Philips DVDR880 DVD Recorder
Disc error occurred repair disc now.if i repair will my recordings be cleared.vdr-d100
If you replace the dvd drive assy in the vdrd100 it wont destroy the recording on your discs and the other recordings should play just fine, provided that the discs arent defective or the recordings on them are ok. I hope this helps
Sep 04, 2010 | Panasonic PV-GS500 Camcorder
Getting disc read error
THere are a number of problems that can cause a disc read error. The lens can be damaged or very dirty. The motor that moves the les could be stuck or damaged. The disc could be dirty or scratched. Or the disc format might not be able to be read by the player. Do you try more than one disc? Are you trying different types of discs? like store boght discs and recordable discs. Some players wont read mp3 or cd-rw discs.
Jun 20, 2010 | Alpine CDA-7894 CD Player
My recorder wont record on new discs
Daewoo DVD Recorder/VCR combi (I believe the model number is DF-4100P it wont record on disc but it will on tape mode plus the drawer in the dvd wont open please can someone send me an answer of whats wrong with it thank you
Apr 05, 2010 | Daewoo DVRS05 DVD Recorder/VCR
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Jul 08, 2009 | Philips CDR770 CD Recorder
Funai DR-B2737 DVD recorder wont record
use mr dvd discs-dvdr youcan buy at poundland they are the only discs that seem to work
Mar 25, 2009 | Sony Ericsson w580i Cellular Phone
Disc Reading Error
my remote wont work recorder
Mar 24, 2009 | RCA DRC8300N DVD Recorder/VCR
Problems finalizing discs
Check to see if you are using 16x media.  If you are you need to get a firmware upgrade from Toshiba.  Contact their support number listed inside of the manual.  They will ship you a dvd to insert into the unit.
Nov 02, 2006 | Toshiba DR4 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Logo
244 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
