posted by whitebuffalo on Apr 08, 2008
I have a JVC model # AV-48WP30 it just started showing doubles with red and green highlights I want my tv back. I tried to center it to no avail PLEASE (HELP)! my contact # is cubianmohawk01@aol.com or (609)465-9554 Thomas Thankyou
2 Other Users Have The Same Problem
Comment by lost in sace, posted on May 06, 2008
my convergance are way off cant adjust red
Comment by turner55, posted on May 01, 2008
what size pico fuse do I need and how hard is it to replace the ICs, the fuse and the resistor? Does this require a lot of soldering?
Best Solution
posted on Apr 08, 2008
You will need 2 new convergence ICs STK392-110 also the 1.8 ohm resistor and the pico fuse usually burn with that model. the ICs are located on the small board located behind the speaker grille and access panel in front. Easy repair go to the following link and you can get replacement ICs and any other part you need. And they provide installation instructions as well as free on line instant meassaging for all customers when they do thier actual repair. Heres the link.
http://servicemanuals.vstore.ca/
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for JVC AV-48WP30 48 in. Rear Projection
Email this problem
Email this problem
Can you Help with these Projection Televisions problems?
JVC AV-48WP30 48 in. Rear Projection...
JVC Big Screen: Screen Bowed...
The screen is bowed top and... Answer This...
HORIZONTAL LINES ON TOP OF THE...
shows greenish horizontal lines... Answer This...
problem with your tv
I am having the same problem... Answer This...
JVC AV-48WP30 / convergence
I changed the ic's and the ohms... Answer This...
Problem on JJVC AV-32WFP1EK
I have a problem with my JVC... Answer This...
Repair Service
Find Projection TV Repairman Near You:
