Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
I have a Raypack RP2100 poolheater. The temp. display shows a much to high reading. (set at 86, inlet temperature shows 84 and pool water temperature is 74) I wonder if the internal by-pass valve or the governor are defective
    Top Expert:
  • Raypak Master
  • 5,706 Answers
Temp sensor try to calibrate first
Posted on May 25, 2016
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: I have a Raypack RP2100. The heater will not turn
What is the pressure gauge reading and what is the pump horsepower?
Posted on Dec 29, 2009
Raypack 2100 pool heater runs for a couple of minutes then loud banging noise. heater shuts off and error code HL appears
That HL is your high limit shutting the heater down. The banging is the sound of water boiling in the heat exchanger because it is moving too slow. This is almost always the result of the bypass or governor (thermostat) not working properly, so too much water is bypassing the heater. It's not too hard of a fix.
Dec 17, 2013 | Raypak RP2100 DIGITAL POOL HEATER R265
How to repair a Raypack pool heater that displays a ROL fault code?
simply replacing the roll out fuse wont solve your problem. those safeties open from an over temp situation or negative pressure down draft. clean out any dirt and debri from venting, inspect the underside of heat exchanger for build up or soot. ensure you have proper combustion/ventilation air openings if heater is in a shed. if heater is outdoors, Raypack is notorious for getting downdrafts back down the draft hood causing burner flames to come outside the burner box
May 20, 2012 | Raypak Rp2100 Pr406aen 406k Natural Gas...
CLK code will not heAT
Not sure about your specific heater, but if the heat won't go on, it could be the water pressure sensor or one of the temperature sensors.
May 05, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Codes for model 335B Raypack Gas Heater
Codes should be found inside of the cabinet in the uper left corner.
If they are not there, here are the basics
EOL = Testing mode
BDI = BOARD FAILURE
EEP = MEMORY CHIP FAILURE
PRS = PRESSURE SWITCH FAILURE
HL1+HL2 = HIGH LIMIT EXCEEDS 135F
SPR = AUXILLIARY INPUT FAILURE
ROL = ROLL OUT SENSOR TRIPPED
SNS = TEMPERATURE BELOW 36 OR ABOVE 110F
FFL = FALSE FLAME SIGNAL
GCO + GVC = POWER TO GAS PV OR MV WHEN NOT SUPPOSED TO BE
FAN = AIR SWITCH OR FAN FAILURE
TAB = TAB FOR LO NOX NOT BROLEN OFF OR AIR PRESSURE SWITCH FAILURE
ILO = PROPANE GAS LOCKOUT AFTER 90 IGNITION TRIAL
IGN= LOSS OF FLAME OR FLAME SIGNAL
Sep 12, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Would like to increase maximum temp to my spa. Have tried to add resistance to sensor adapter wires coming off thermistor (at input/output headers) to no avail. Using RP2100 raypack - 265K BTU heater with...
Hello Alan. You are going to run into a few internal safety devices that will prevent you from doing what you hope to do. You're going to have a problem overriding the temperature. The Consumer Product Safety Commission and other agencies helped our industry in setting into place "high limits" (therefore the use of high limit switches). It's my understanding according to several doctors that water temperatures over 107 F are dangerous for soaking. You can become so relaxed that your body's core temperature rises! Hyper-thermia is just as dangerous as hypothermia.
Our advice to our customers over the years has been, if the water feels even a little hot (not warm), don't go in. We want our customers to have a safe, long life with their hot tub!
Jan 16, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak RP2100 pool heater set temperature stuck on 50 degrees
Could be spider webs in the orfices, which would allow the burners not to light.
Could also be a bad thermostat or pressure switch.
Jun 19, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
