I installed windows 7 onto my computer , now when my computer boots up it does not go directly to my hard drive and boot up windows 7. When the computer starts to boot I have to click the escape button (boot menu) and then manually select what drive I want to boot from . Help how do I fix this ?
  • 1 more comment
  • Adnan Bhatti
    Adnan Bhatti May 29, 2010
    Set the boot device priority from within BIOS.
  • Jimmy Accardi May 30, 2010
    did not work , there was an error : the element data type specified is not recongnized , or does not apply to the specified entry. run "bcdedit /?" for command line assistance
    that was the first thing I tried and its set properly but still not booting
    Novelist:
  • 76 Answers
Open up the command line as an administrator or user w/admin rights (right click on the Shorcut > Run As and lets you run as an admin if your on a non-admin account)
2. type this command to see the current state of affairs.
bcdedit
you prob will see something like this (my original boot option)
__________________________________________
D:\Users\seamonkey> bcdedit
Windows Boot Manager
identifier {bootmgr}
device partition=C:
description Windows Boot Manager
locale en-US
inherit {globalsettings}
default {current}
displayorder {ntldr}
{current}
toolsdisplayorder {memdiag}
timeout 30
Windows Legacy OS Loader
identifier {ntldr}
device partition=C:
path \ntldr
description Earlier Version of Windows
Windows Boot Loader
identifier {current}
device partition=D:
path \Windows\system32\winload.exe
description Microsoft Windows Vista
locale en-US
inherit {bootloadersettings}
osdevice partition=D:
systemroot \Windows
resumeobject {1ecfd635-a8ea-11db-bb9b-ddf07c6aaff1}
nx OptIn
to change the default boot os to 7 from xp use the command
bcdedit /set {ntldr} default “{bootmgr}” in the command prompt ,restart and then check .
all the best, hope this post helps you ...
Posted on May 30, 2010
Testimonial: "very good thank you , good instructions and clear explanation "
If u press f2 on start up u enter setup then from there it gives u the boot options if u put harddrive first then u problem is solved
Posted on Apr 02, 2012
Computer cannot boot
Usually if windows doesn't boot it lost boot.ini usually this happens if you had an install disk left in and you didn't exit an install the way the disk wanted you to. To correct this put in your windows cd and use it's repair function. If you don't have a windows install cd take your hard drive out and add it to another computer to slide a copy onto it. You can write your own boot.ini on a notepad and save as boot.ini. If it were an XP operating system you could go to DOS and copy a boot.ini to where it needs to go. Lots of options.
Nov 10, 2013 | google.com
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
Tip
Windows 7 will always boot to drive letter C: in multiboot configurations.
When configuring a Multi-boot configuration using Windows operating systems, you need to install Windows Versions oldest to newest on separate partitions. In doing so, Windows 7 is going to be installed to Drive D: or E: or such. In all previous versions of Windows, if you have a multi-boot configuration, the drive letter for that OS is always the same as the drive where it was installed.
Windows 7 does things a bit differently. EXAMPLE: I have 3 partitions on my hard drive. C:, D: and E:. XP on C: Vista on D: Windows 7 on E: When I boot to XP, the boot drive letter is C: When I boot to Vista, the boot drive letter is D: (Simple) Well, I learned the hard way that when you boot to Windows 7 from a partition other than C:, it will show the boot drive as C: in Windows 7 (It swaps drive letters with the boot drive and C: transparently). When you boot to the other partitons, the drive letters are as they should be and the change is only effective while booted to the Windows 7 Partition.
on Dec 03, 2009 | Computers & Internet
Hard disk (freedom drive xxs) does not start up. pc is dell xps with windows 7. pc says: this is not a win32 file. ? thank you
Hello
If you are using windows XP and try to install a windows 7 in not proper booting this will appear in your computer, but if you boot in a proper booting this will not appear try to boot in a proper way to install your windows 7
Jul 19, 2011 | Freedom Computers & Internet
I have want to setup Windows xp and windows 7 together .Meaning when start up computer have : Windows xp Windows 7 I try to setup two windows ,but i setup windows xp lost windows 7 and setup windows 7...
Not sure what you have done so far. You need to divide your hard drive into two sections. Install XP first on to one section. Then use a program to manage your computer start up, the one I use is called Easy BCD this is a free program and works great. Once you cut your hard drive and install XP make a copy of your start up partition. Install the Easy BCD program and make a back up again. Then Install Win 7. Then on the Win7 side install the Easy BDC program and set up the menu choices. I run a 3 way boot with XP and Ubuntu. Hope this helps Fix Ya up.
Jul 09, 2011 | Computers & Internet
I just upgrade to Win 7. Now everytime when powering up the machine, there are two boot options like this: Previous Windows Operation System Windows 7 (with Windows 7 highlighted) Of course I...
If I understand you correctly you had a previous operating system installed on one hard drive and you just now installed Windows 7 but on a separate drive? When you boot the machine if gives you two boot options, the old OS and the NEW OS?
What your going to have to do is format the drive(erase) that contains the old operating system. Format as NTFS.
Try unplugging the old drive, making sure the new drive is set to master and not slave. Boot up the computer.
When you boot up your computer you should immediately get options. One of these options should say "press delete for bios" or press "f6 for settings" You need to go into the bios and make sure the drive with Windows 7 is set to your primary drive in the boot order(hard drive should be first in boot list). We want the computer to boot to the new drive first.
Once you get into Windows you can use a program like partition magic to format the old drive to use as just storage space. You can even use "diskpart' which is an old windows command line utility.
If you reinsert the Windows Disk when you are booting up you will get some recovery options, and if I recall correctly one of these should let you format hard drive space. So, you may be able to do it from there.
Where exactly does the error come up in the boot process? Are you able to boot into safe mode? It may be easier for you to just reinstall Windows 7. If you boot the computer with the disk in the drive, and the BIOS set to boot first to the disk, then during the installation configuration you should be able to have Windows just format the old drive to use as space and install the MBR on the new drive.
-G33k
Jun 11, 2011 | Microsoft Windows 7 Ultimate for PC
My laptop does not boot. it always ask for a cd to boot but i already reformat it.someone told me that it is a hard disk problem and advice me to replace my hard drive.
When the computer starts it flashes up press f2or delete or some other key to enter setup. Go through the settings and there should be one that will allow you to change the boot device. It sounds to me like it is set to boot from the cd rom drive only. Change it to boot from the hard drive and save changes to CMOS and restart the computer. The computer should now boot from the hard drive.
Aug 01, 2010 | Compaq Computers & Internet
Copy WIndows XP from one hard drive to another
Why are wanting to clone your hard drive to another on when all you need to do is install Windows 7 directly onto the new hard drive?
Are you wanting to save all your settings and data before you install Win 7 over the top of XP?
Jul 20, 2010 | Microsoft Windows XP Professional for PC
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
Want to comp re format hard drive and then install
well if u have windows 7 disc, then u can use that to boot the computer from the disc n then it will give u option to format the hard drive and install the new os.
u will have to boot the computer from the windows 7 bootable disc.
Nov 01, 2009 | Dell Optiplex 740 Desktop Desktop Computer...
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
