Question about Hayward H-series Electronic Gas Pool Heater H400
The digital display panel on my hayward h400fdn gas heater is not working and it appears that all the fuses are fine just wondering if maybe the board itself is bad
  • 8 Answers
SOURCE: I just installed a new Hayward H400FDN and it will not stay lit.
I had the same issue...you don't have enough gas pressure.
Posted on May 12, 2009
john224
  • 1378 Answers
SOURCE: Smoke or vapor coming from new h400fdn hayward pool heater.
Not at all uncommon. New heaters have to glaze over the file tile in the burner chamber and will often smoke and smell during the first week or so of operation.
Using a mirror, check to see that your flames are about 4" proud of the burner tubes when running. As long as they are and the color is a nice blue with little to no yellow/orange color, the heater is fine.
Posted on Jun 14, 2009
  • 64 Answers
SOURCE: Hayward H400FDN won't stay lit
It is probably not sensing flame. You either have a clogged orifice underneath the flame sensor and you probably need to have the gas pressure assessed, meter size and gas valve pressure adjustment. These heaters need 2" wc of gas pressure.
Posted on May 20, 2010
  • 31 Answers
SOURCE: My Hayward H400FDN heater will not switch out of
Try resetting it by turning off the breaker that supplies power to the heater. This should be located in the power box at the pool equipment. It is probably a 15 amp breaker.
Posted on Apr 18, 2011
  • 910 Answers
SOURCE: Hayward H400FDN pool heater It
The Error is Sb which indicates a fault with the Keypad which requires replacing.
There are 2 options for this part.
FDXLBKP1930
http://www.amazon.com/HAYWARD-BEZEL-KEYPAD-ASSEMBLY-HEATER/dp/B004GQHKMK
FDXLBKP1931
http://www.parts4heating.com/Hayward-FDXLBKP1931-Bezel-Keyapd-Assembly-Kit-FD-p/fdxlbkp1931.htm
Posted on Jul 16, 2011
Hayward H400FDN will not stay lit - Brand New install - NO Fault codes.
make sure wiring is correct especially if wired 120 volt read instructions inside panel
Jan 28, 2014 | Hayward Industrial Products H400FDN...
Error code HS on hayward heater H400FDN
check the fusible link if blown check gas pressure
Jan 28, 2012 | Hayward H400FDN Low NOx Natural Gas Pool...
Hayward H400FD. Can't adjust temperature.
need new display board also check if connected to a system disconnect and try alone
Apr 17, 2010 | Hayward H400FDN Low NOx Natural Gas Pool...
"LO" error code on new H400FDN heater
it is low water pressure sensed, unit will not start unless pump is working
Jun 07, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H-series Electronic Gas Pool Heater H400 Logo
242 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
