Question about Weber SPIRIT E-210 (NG)
Natural gas regulator
I just bought the Weber Spirit E-210 - natural gas and I just had a natural gas line ran out to my deck. Do I have to install a regulator?
  • Anonymous Mar 23, 2014
    weber 210
  • 43,501 Answers
No.. the gas pressure that is run out to the grill should be low pressure allready...just hook it in leak test it and you are good to go....
My grill sits right by my meter about six feet away... I tee'd off at the meter installed a valve and then run right into the grill....works great!!
heatman101
Posted on May 29, 2010
Weber Spirit 210 Won't Get Hot
Try following these steps to reset your FLD (flow limiting device)http://www.edyoungs.com/edyoungs/troubleshoot_tank.htm and then carefully follow the lighting instructions. If it works for you I think you will find this is a GREAT grill! Happy grilling and eating!
Apr 19, 2014 | Weber SPIRIT E-210 (NG)
Weber e-210 LP to natural gass
Need to replace the jets on the regulator, or the regulator itself if it can't be re-jetted. Nat gas needs a larger orifice, has fewer BTU's than LP.
Jun 18, 2012 | Weber Grilling
Low flame - doesn't heat enough
Hi, Patty. The low burner flame on a natural gas grill an be caused by several things.
1. The gas line shutoff valve is not fully open.
2. The burners are clogged and need to be removed and properly cleaned
3. The venturi valve(s), which has spider screens may be clogged.
The things listed above are the top 3 reasons for the low burner flame problem on a Natural Gas Grill.
To help you accomplish the cleaning of the burners and the venturi valves, I have included a link to your Owners Manual, that you can download & print for future reference. It has detailed instructions and diagrams in the Maintenance section, that will show you how to accomplish this.
http://help.weber.com/manuals/pdf_files_2011/Gas/Spirit%20ES%20Series%202007newer/OwnersGuides/Spirit_210310_NG_OwnersGuide_89961_022811.pdf
Hope this helps you to solve the problem. Please let me know. Thanks and Happy Grilling!!
May 14, 2011 | Weber SPIRIT E-210 (NG)
Can a weber spirit e210 natural gas grill be converted to LP gas? I won the grill but don't have natural gas at my home
Weber sells conversion kits. Basically, you need a new regulator and manifold to accommodate LP instead of the existing regulator/manifold setup for natural gas. Unfortunately, Weber does not sell their parts online. Their parts phone # is: 877-731-8081
Apr 27, 2011 | Weber SPIRIT E-210 (NG)
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
Cannot light my spirit gas grill
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101 ';
Feb 21, 2011 | Weber SPIRIT E-210 (NG)
Grill not heating when gas and flame is on
heatman101 ]\
Feb 12, 2011 | Weber SPIRIT E-210 (NG)
All of the sudden my grill will only heat up to around 350 degrees. It is about a year old and has worked flawlessly up till now. It lights and the flames seem to be coming out of all burners but just...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
heatman101
Sep 03, 2010 | Weber SPIRIT E-210 (NG)
Conversion kit for Weber Summit LP to Natural Gas
Hi, you can purchase your kit at amazon, click here and take a look: Amazon com weber grill conversion kit to natural gas. I hope this was helpful. Cheers
May 31, 2009 | Weber S-420 (NG)
I want to convert to natural gas.
The only thing you can do if Weber doesn't have a natural gas manifold for their grills , is to buy one that will fit. They use propane on outside grills because of the stability of the gas. Natural gas will blow out much easier.
Feb 25, 2009 | Weber Genesis Silver B Grill
Weber SPIRIT E-210 (NG) Logo
202 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
