Question about RCA 20F424T 20" TV
My RCA 20F424T whines at a high pitch. Does anyone know what this might be? Thanks.
5 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: high pitched whining
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). The sound comes from the flyback unit.
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
It may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
IrishDruid
Posted on Oct 04, 2008
  • 4 Answers
SOURCE: RCA F32650
If it weren't for the high pitch whining noise. I would say it probably is an internal fuse inside the chasis. It is rated at 1.5 to 2.0 amps. With the whining noise it sounds like a trouble shooting bench
job. Problems occur when a electrical/electronics device is turned on and turned off. Inrush voltage,
when it is turned on, can go up to three times more than normal. This also happens at turn off. Solid state components usually fail at this time. I don't feel that this is a problem that can be fixed in the home.---BBB
Posted on Jan 27, 2009
SOURCE: my rca tv 20f424t doesn.'t show thw correct
That is the Digital range of channels, since it is digital you will not need a converter box for this model. Their is also an Analog range of channels which is the primary setting, You will need the factory remote to switch from Analog to Digital... Without that remote you might have a problem their isnt a way to switch within the menu settings, good luck!!!
Posted on May 31, 2009
techman007
  • 1112 Answers
SOURCE: my rca tube tv has a high pitch whine when i plug
Hello you have a shorted Horizontal output transistor, also if you replace it also have the Flyback transfromer replaced also, these parts work in conjunction with each other, and if one goes bad its best to replace them both.
Posted on Dec 21, 2009
"Still no power". After replacing cp114, cp120, cp130 and cp 135 on my RCA D52W20B, when powered on the green comes on along with a high pitch sound making several attemps to power on before completel
The whine is a short somewhere---+ and - are marked on the board for each cap if it is polarized---usually the - will have a shaded white mark on top of board--if you got one in backwards it can explode......
Apr 13, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Making high pitch whine or squeeling
Check the color wheel and any fans running on the unit. The color wheels make a high pitch whin right before they quit as well as the cooling fans.
Jul 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
A noise had been gradually increasing from a grinding sound to a high-pitched whine. COntinues until the screen is completely off. Sounds like a fan motor may be out of lubrication.
THAT TV HAS WHAT IS CALLED A COLOR WHEEL WHICH SPINS AT VERY HIGH RPMS AND CAN MAKE HIGH PITCHED WHINING/GRINDING NOISES IF A FAN WAS BAD THE TV WOULD SHUTDOWN AND THE SOUND WOULD BE MORE DULL SOUNDING.
Dec 17, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
High pitched whine/sometimes TV won't turn on
The power supply on this model will whine when it is shorted or overloaded - the set would have to be brought in to determine exact cause.
Oct 23, 2009 | Televison & Video
RCA D52W19B makes high pitched buzz when on
Sounds like a coil is vibrating or a component is bad causing the transformer to whine. Could possibly just need soldering.
Jul 08, 2009 | Televison & Video
RCA F32650 production May 2003. Was working fine. Turned it on the next day, got no picture and a high pitched whining noise.  Please let me know what I should do to fix it.
Jan 25, 2009 | RCA F32650 32" TV
High Pitch Whine from Amp (not speaker)
make sure your rca andpower/remote wires are ran on seperate side of your car.it maybe recieving some kind of interference from the alternator. try buying higher shielded wiring too
Apr 20, 2008 | Hifonics Brutus BXi 1206D Car Audio...
High pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection board..it basicaly a large coil of copper wire....you can take silcon and put on the coil...in effect damping the ocillations...hope that might help
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52w66
solder around flyback pins ,also these sets are having major problems with flyback transfromers/high voltage tripplers.let know how you come out after soldering HV transfromer.
Jan 26, 2008 | RCA D52W19 52" Rear Projection Television
RCA 20
sounds like the Power Transformer to me,  usually accompanied by a high pitch (almost inaudiable whine) and  sparks arcing.
This needs a professional repair..
Oct 11, 2007 | RCA F27252GY 27" TV
RCA 20F424T 20" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
