Question about Samsung AW0803B Air Conditioner
When I turn on the a/c there is a humming noise and the fan does not come on. Do I need to replace the fan? Is it difficult/expensive?
  • Samsung Master
  • 43,501 Answers
Before you replace it, pull the cover off and see if you can get some WD-40 worked into the shaft bearings...spray the shaft at each end with the WD-40 and then spin the motor by hand with the power off...after a bit the shaft may loosen up and then you can plug it in and get it running...then lubricate the bearing by dropping a few drops of light motor oil where the shaft enters the motor....
If the motor spins freely but does not run then it will need to be replaced..this may cost more then your unit is worth...matching up a motor can be difficult but changing it really is often not that hard...if you can get the fan blades off easily...
heatman101
Posted on May 29, 2010
Buzzing/humming noise won't stop. Lamp was replaced a year ago. This just started and the noise is near the lamp. The noise won't stop while the TV is on and lasts for a minute when the TV...
If its a DLP with a high pitched or even fan like sound it is the color wheel--Mitsubishi does not sell them as a part---you would have to replace the entire light engine (expensive and may not be available any more on a older set) .
Nov 08, 2012 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Humming noise when turned on
The montherboard doesn't have anything that would make a humming noise. In all likelyhood it's the fan that sits on top of teh processor. It could be normal, but might need to be replaced or cleaned.
Mar 01, 2011 | Computers & Internet
Humming noise
If you are using a dimmer switch to operate the fan instead of a fan speed controller, that is the cause of the humming. If you turn down the speed to the lowest setting and the hum gets louder, then your controller needs to be replaced.
Sep 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Makes a loud noise when it is turned on. Can't open it.
If it is making a loud humming sound it is probably getting weak and will have to be replaced. Is it doing it in all speeds? Motor replacement would probably not be worthwhile unless it is a very expensive unit. I'd opt to replace the unit.
May 16, 2009 | Bionaire BT45RC Tower Fan
Motor Hum
check your grounds and all other connections. remote wiring has to be precise. somes times not for the do it your selfer. all the labor youve encountered somes the cheap can turn out to be very expensive.
Apr 26, 2009 | Hunter 52" Ceiling Fan With Light And...
Humming noise
The light enigine shouldn't be that difficult to replace if you have a decent amount of time and are moderately mechanically inclined. You can order the original Toshiba replacement light engine for this model (62HM95) from a major Toshiba parts distributor at the link below:
Toshiba 62HM95 Replacement Part Light Engine / Optical Block
Apr 01, 2009 | Toshiba 62HM95 62" HDTV
Toshiba #62HM95
I am wondering if this sound might be your color wheel spinning. The color wheel often makes a low humming noise as it spins. Try checking to see if this is not the source of your noise. You need the color wheel to generate the colors needed to turn the B&W picture generated by the DLP into a color picture.
Thank you,
Shuttle83
Nov 08, 2007 | Toshiba 62HM95 62" HDTV
Samsung AW0803B Air Conditioner Logo
177 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
