Question about HP PSC 1410 All-In-One InkJet Printer
Pink copies My last two color ink cartridges keep printing out pink. What does this mean?
  • 3 Answers
Most printers is run by 4 colors black and the colored is basically yellow red blue. (or may called it magenta cyan etc)
1. One of you colored ink runs out that why you cant make any colored.
2. Or one of the basic color might be clog up, dry or simply empty.
3. you need all the 3 colors to make all the colors available.
e-mail me at wendel_tenebroso@yahoo.com
good luck
Posted on Apr 08, 2008
I have an HP Photosmart C3180 printer color ink issue. Instead of printing yellow its printing pink. I've cleaned the head multiple times and the ink cartridge is brand new. Please advise. Thanks!
If what you're saying is still the result after cleaning everything up, there must already be something wrong with the printhead because the printheads are the one's that are responsible for the mixture of the ink cartridges.
Try calling HP Tech Support. They might still be able to replace the printheads for you.
Feb 03, 2011 | Office Equipment & Supplies
Printer does not print in color but only prints in
Run a "print-head-cleaning-cycle" -- the ink inside the cartridges is not getting through the ink-jets, and is not reaching the paper.
Either that, or the electronics inside the ink-jets are malfunctioning, i.e., not telling the ink-jets to shoot the ink out.
Jul 21, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Testing color ink cartridge
Remove the print cartridge and press the head of cartridge on the tissue paper firmly.if the cartridge is okay it should shows three colors on the tissue.that are cyan(blue), yellow and magenta(pink).if you see any color missing that means the particular color is empty or dried up.get the cartridge refilled or replaced if necessary.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 28, 2010 | HP DeskJet 710c InkJet Printer
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
The printer does not print reds and pinks
Follow www.kodak.com/go/itg and try the step by step solution.If issue persists,Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy..
Dec 26, 2009 | Kodak ESP 5 Printer
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
Printing not complete
you may check your ink cartridge
1) the cartridge some color almost empty, need to change a new one or refill the match color ink. test it and go next if not fixed
2) long time less using cause some color ink chanel(holes) dryer, you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 Hr, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Feb 06, 2009 | Lexmark X75 All-In-One InkJet Printer
Printer S400 won't print out blue and pink ink
Hi..
The nozzles have gone bad...it needs to be serviced or replaced...i appreciate your efforts yoy put in to fix the problem thats best we can do after all its a machine.if the printer is in warranty contact the manufacturer.
Regards,
debroy
Nov 25, 2008 | Canon S400 InkJet Printer
Color now is pink, does this mean I should repace cartridge @HP D4160
yeah replace the color cartridge, first allign the cartridge if problem presists then change it
Oct 31, 2008 | HP OfficeJet 6210 All-In-One InkJet...
DeskJet 950C Pink Printing problem
Assuming that you have the correct print drivers and the color is set correctly on your software. Then the issue is often caused by the ink drying and clogging the injectors. Open the lid and remove the ink cartridges, then unplug the printer. Then get a swab or Q tip and using bottled water (do not use tap water). Moisten the swab and wipe the areas on the printer where the ink cartridge contacts the printer. You should see ink on the swab. After you let it completely dry then place the cartridge back in and turn the printer back on. Try to print again. If it is still not printing with the correct colors then you could have a problem with the injector circuitry. At that point it is cheaper to buy a new printer. You can get refurbished ink jet Dell printers at Dell.com under outlet for usually $30-$40 and a one year warranty.
Jan 04, 2008 | HP DeskJet 950c InkJet Printer
HP PSC 1410 All-In-One InkJet Printer Logo
118 people viewed this question
Ben Johnson
