Question about Maytag MTF2156GEW Top Freezer Refrigerator
Icemaker on our MaytagMTF2156GEW top freezer overflowed with water to the point of overflowing the whole bin that stores the ice, even soaking the floor around the refrigerator. Does the ice maker control the fill valve?
    President:
  • 1,218 Answers
Good day,
Yes, the ice maker controls the water valve in the sense it turns the valve on for approx. 7 seconds per cycle.
However, it is not the common method for causing flooding. 99% of the issues are caused by the valve refusing to close properly.
The only way the ice maker could be at fault is if it hung at that precise position and refused to advance to it's normal parked position.
However, there is the 1%.
Posted on May 29, 2010
How to fix lower freezer, the water dispenses too much into ice cube tray so it overflows into ice bin...
There is an adjustment on your icemaker that controls the amount of water that enters the tray during the fill cycle. Find it and turn it counterclockwise to lessen the water in tray so it does not overflow.
Or, check to make sure that the fill solenoid is shutting down properly (could be sticking)- if not excessive water will enter the tray with same result.
Mar 03, 2017 | Refrigerators
My maytag mfi2568aeb french door bottom freezer has ice on coils in freezer and ice maker wont make ice
Sounds like the icemaker drain is clogged and the fill process overflowed the unit. the water then froze the drain and all overflowed water from icemaker. Remove icemaker and remove all ice from freezer and icemaker. Clean all drains. Reinstall.
Nov 19, 2014 | Refrigerators
How do I control the amount of ice in the freezer? When I open the freezer door ice pours out onto the floor and in the freezer itself.
That is going to a internal problem in the icemaker,is has a sensor that when it detects that the ice bin is full its supposed to cut off the icemaker so it doesnt overflow and continue making ice such as your experiencing. By replacing the icemaker it will shut off when the storage bin is full.
GENE
Sep 26, 2011 | Refrigerators
GE profile refrigerator pss266msra has a problem with the freezer. Replaced the thermistor and heater as suggested since I had ice buildup. Now icemaker is leaking water which is freezing into icicles -...
One of two things is happening.
1) the fill tube leading from outside the box into the icemaker may have ice buildup or is too close to the icemaker fill wall. Make sure there is a gap between fill tube and wall and check for ice in the tube.
2) wait for the icemaker to call for water and see how long is calls water for. It is only suppose to be 7.2 seconds. If it calls for water longer it can be overflowing. If overflowing than replace icemaker.
Usually there is ice buildup or something that the water is hitting and splashing everywhere.
If you have anymore questions or need more assistance please comment.
Aug 01, 2011 | GE Refrigerators
Ice cube tray overflowing-not shuting off automatically
Yes that is a plastic extension for the icemaker shut off. When replaced the new one should be secured with two small zip ties. You can use the ice on/off button to shut the icemaker off manually in the mean time. When ice is displayed in the panel it is on and when it is off so is the icemaker.
Jul 20, 2009 | Sub-Zero 650 / O Bottom Freezer...
Ice maker feeding too much water and overflows
I have the GE Profile TFX24PR that exhibited the same symptoms. I had water leaking, making ice in the bottom of the ice bin, as well as under the ice bin. I also discovered ice down the back wall of the freezer.
A technician replaced the ice maker, which did not solve the problem. He put the original back and replaced the valve on the back. That too did not solve the problem. I took matters into my own hands.
I discovered that the ice maker water fill tube that comes in through the back of the freezer wall was leaking. Water would run down the outside of the tube. Some of the water would go into the ice maker, some would go into the ice bin and some of the water would also run down the wall of the fan housing where it passes through a hole in the fan housing. The big problem was the water running down the wall of the fan housing. From there it ran onto the cooling coils, where it would freeze, causing the freezer to go into extended defrost. My freezer and fridge would warm up and I had some food spoil.
If this looks like it may be your problem, you may want to enlist some help for this; it is tedious, time consuming and requires working in the confined spaces of the freezer.
After disassembling the fan housing I was able to access the fill tube. It just pushes in and is prone to wear, especially after fourteen years. I just reversed the ends of the tube and pushed it back in for a snug fit. You may want to consider using a sealer. Everything is working fine now; lots of ice in the bin, and no stray ice or water.
Nov 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker overflows with water
yes, in fact the icemaker does meter the amount of water delivered to the icemaker, the valve should only be energized for 7 seconds. after that the power is cut off, so if valve continues to let water flow, it's bad (might have debris from water line keeping it open. unserviceable. )
Mar 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Maytag MTF2156GEW Top Freezer Refrigerator Logo
139 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
