Question about Maytag M7DH45B2A Dehumidifier
Dehumidifier element icing up
My dehumidifier keeps icing up...very quickly. Serial #CS 895024 071@, model # M7D445B2A . The filter is totally clean, we've placed it up off the floor (in a NOT-wet basement)
  • Maytag Master
  • 43,501 Answers
Unit is low on charge...
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Posted on Sep 30, 2010
My Kul Dehumidifier filter keeps freezing up? is there anything I can do to keep this from happening?
Turn the knob to a lower setting so that the unit cycles on & off. This will give it time to warm back up and melt the ice in between dehumidifying runs.
Aug 30, 2015 | KUL 50 Pint Dehumidifier"
Wht does my dehumidifier keeps getting ice build up
Possibly dirty. Remove and clean all the filter parts and inner coil.
Be careful not to damage any of the cooling surface area.
Most of the time, you will get improper airflow from blockage.
Completely clean and try after to see if this corrects this issue.
Oh, a new filter if you have one.
Aug 05, 2014 | Dehumidifiers
Esco Oasis 2700L dehumidifier ices up. Is there a filter to be cleaned and if so, how to I get to it?
The most common cause of frost and ice buildup on a dehumidifier is because the unit is operating in temperatures that are too cold. Many dehumidifiers are not equipped to run at temperatures below 65 degrees Fahrenheit.
To fix this problem, Position the dehumidifier in an area where there is at least one foot of clearance around the unit in order to allow for proper air circulation during its operation. Close all windows, doors and other outside openings to make sure your unit isn't attempting to remove moisture from areas outside of the immediate room. Determine the temperature of the room by checking a nearby thermostat or by using a hand-held thermometer.
Check the filter for dirt and buildup. Unplug the unit from the electrical source and check the filter by opening the filter compartment. If the filter is dirty, it will restrict airflow through the unit and lead to freezing. Soleus recommends lightly vacuuming the surface of the filter to remove dirt. The filter also can be washed in warm water if it is extremely dirty. Once clean, place the filter back in its compartment. Allow for the ice to melt and then restart your dehumidifier.
Jul 03, 2011 | Dehumidifiers
3 year-old machine. Appears that the main refridgerant supply line to the coils ices up soon after you turn it on, starting near a small canister of some kind, then the ice makes it way across the...
Often times, a clogged filter will cause them to freeze up. Because, it's not getting enough air into the system to warm the coils. If you haven't cleaned the filter recently or regularly, that is more than likely the problem. Other than that, the ambient room temperature can play a role in it. If it's cooler than 41 degrees, the humidifier struggles. Same is true if it's over 93 degrees.
Hope this helps you solve the problem.
Mar 11, 2011 | Kenmore 54701 Dehumidifier
Dehumdifier not collecting water.
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
How do I clean the dehumidifier?
A dehumidifier works just the way an air conditioner works but in a reverse manner. If you encounter a problem with your dehumidifier then it would be repaired the same way you would repair an air conditioner. As such a dehumidifier does not require much cleaning apart from changing the filter. When the filter and coils of the dehumidifier are choked with dirt, it may not pull out moisture from the air properly. The efficiency of the dehumidifier gets decreased and the only solution is, to clean it thoroughly. In order to assist you with the cleaning procedure of a dehumidifier, following are a few tips:
  1. Remove the water tank/container and clean it after draining the water. Depending on the usage the container must be cleaned regularly.
  2. Cleaning or changing the filter is also important for the main function of ensuring a healthy atmosphere is performed by the filter. Mix some bleach with warm soapy and clean the filter. It will help to get rid of the bacteria, molds and mildew.
  3. Use a vacuum cleaner to clean the evaporative coil/hot coil. Scrub off the dirt using a brush but make sure that you don’t bend the fins while cleaning.
  4. Clean the condenser or the cold coil the same way. If the humidifier is working in a room where the temperature is below 60 degrees Fahrenheit then check the coils whether it is not icing up.
  5. See to it whether the fins are bent or not, if they are bent then straighten them out using a fin comb otherwise it might obstruct the effective working of the dehumidifier.
  6. And yes do not forget to clean the fan blades and other parts of the dehumidifier.
  7. Keeping in mind the humidity level of your room, sets the humidistat of the dehumidifier as keeping it too low or too high may only make the dehumidifier to run longer than necessary.
Also before you start with the work of cleaning the dehumidifier, make sure that it has been unplugged.
Aug 17, 2010 | Fedders A7DH45B2A Dehumidifier
My filter and the inside keep getting caked with ice even though my basement never gets below 55 degrees
this is most likely because of bad air flow... check your fans are working,, check your filters are clean
Nov 10, 2009 | Whirlpool AD25BSR Dehumidifier
LG dehumidifier developing ice
First you would need to clean the filter. LG recommends cleaning the filter every 2 weeks on their dehumidifiers. The second thing you need to do is clean the coils periodically. On this dehumidifier it should include a brush for cleaning the coils. It is located on the top of the bucket. To access the coils the following needs to be done:
1.) Unplug the unit from power
2.) Remove the bucket and also the air filter
3.) Remove the front pannel by removing the 2 lower screws and depressing the tabs.
4.) Once the panel is removed you will see the coils. You need to clean them with the brush. Go in an up and down motion to remove the dirt and dust.
Now use the reverse steps to put it back together. If your dehumidifier runs often I recommend you clean the coils about every 3 to 4 months. This is a common problem on alot of dehumidifiers and people think their dehumidifier is broken. Most of the time the coils are just dirty which causes the water to stay between them and freeze. Keep me posted. Also if you found this response helpful, please rate this solution when you get a chance. Thanks - Tech101
Jul 01, 2008 | LG Goldstar LD65EL Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
367 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
