Question about Harman Kardon AVR 25 MKII
My receiver doesn't have a dedicated subwoofer output, can I still hook up a subwoofer? I have a harmon kardon avr 25
    Brigadier General:
  • 8,546 Answers
That would depend mostly on your subwoofer. There are some that slave off the front left and right speaker outputs and still pass the amp's power to the Front Speakers. That would be the only way that would ensure volume control.
Otherwise you have to feed a self-powered sub from the Tape Outs but that won't allow volume control from the H-K.
Posted on May 29, 2010
Harman kardon avr 1500
Try using the RCA outputs once and see if that works..One other thing don't use the phono input on the receiver as it could damage the amplifier
Feb 16, 2018 | Audio Players & Recorders
Does the Harmon kardan avr25 have an hdmi output
Nope. You get one component OUTPUT (monitor) and two component INPUTS (Vid 2/DVD) but no HDMI video output.
If you can input and switch HDMI video directly at your display from your cable/SAT etc. you should be fine, just run all the audio through the AVR-25 through the coaxial/optical digital inputs, L/R analog RCA or the 5.1 direct inputs.
Feb 13, 2013 | Harman Kardon AVR 25 MKII
How do you hook up a power amp to harmon kardon 240 receiver
If your receiver has preamp outputs, you should be able to plug and play
Jan 27, 2013 | Harman Kardon AVR 240 Receiver
Monitor output signal
Email or call the manufacturer
http://www.harmankardon.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=AVR%20254
Aug 27, 2012 | Harmon Kardon Harman Kardon Avr 254 7.1...
We are hooking up our harman kardon avr 2600. does the pvr & dvd player go in to the receiver then out to the tv?
only if the harmon kardon has video in (yellow) and video out. otherwise just the audio should go into the harmon
Mar 13, 2011 | Harman Kardon Audio Players & Recorders
My Harmon Kardon AVR 500 sound doesn't work, I disconnected speakers, re connected & reset protection. Nos ound not even on test mode
Hi it is seem there is no output from your device. Please check the circuit components and wires for malfunction in your Kardon then. Regards
Feb 09, 2011 | Harman Kardon AVR 500 Receiver
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
I have Harmon Kardon AVR 25 ii receivers and I have attached it to Bose 701 front speakers and three other Bose surround speakers and an subwoofer. All the speakers work except for right speaker, I need...
To locate the problem...a) Cable
Test if right cable is ok, by interchanging the rt/left cables.
b) Test Bose right speaker
Connect the Bose right speaker to HK's left channel. Works? Then Bose right speaker is ok.
c) Test HK's right output by connecting the left Bose speaker to HK's right output.
Does not work?
Jun 16, 2009 | Audio Players & Recorders
Hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Feb 11, 2008 | Harman Kardon AVR 130 Receiver
237 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
