Question about AEG Kitchen Ranges
F8 fault on D9800VF- no display symbols showing on main oven - hob seems to be working OK
  • 76 Answers
SOURCE: oven turns off and displayes F2,F3,and sometimes F4.
5550 The error code ?F2? will be displayed along with a beeping sound if the ERC (Electronic Range Control) or ?clock? senses a runaway heat condition during the ?cook? or the ?clean? modes. It could be caused by the oven temperature sensor, by the ERC or by the wire harness between the oven temperature sensor and the ERC. If the error code ?F2? is displayed in the ?cook? or ?clean? modes only, then the problem is a bad oven temperature sensor or its wire harness. If the error code ?F2? is displayed in the time of the day mode also, then most likely a problem is the bad ERC. The access to the oven temperature sensor plug and the wires is from the back only. You have to pull the oven out of the wall (if it?s free standing) or remove it from the cabinet (if it?s built in). Disconnect the power and remove the rear cover. Check the resistance across the oven temperature sensor. It is supposed to be about 1100 Ohms at room temperature. If the resistance is incorrect, the oven temperature sensor is bad and needs to be replaced. If not, check all the wires from the oven temperature sensor to the ERC. Replace all wire nuts if any. If it is not the sensor and wires, you have to replace the ERC. To get the right replacement part just click on the link http://tinyurl.com/34ujtl , then type the model number of your oven in the search box, click on the ?search? button and in the new window type the word ?sensor? or the word ?clock? in the ?search by keyword? box and click the ?search? button. Gendos post back...
Posted on Jul 07, 2007
SOURCE: Cannon Camberley 10305G (Double Oven)
trust you have set the clock as this turns the gas supply on to the ovens
Posted on Mar 18, 2008
SOURCE: Gas in main oven
hello, i have looked into the problem and have come up with a fix for mine at least. take out all the trays, and peer into the rear. you will see a silver section which has three srcews. remove the centre one to get access to the burner which has the white igniter on it. this just slips sideways and off. with the aid of a small mirror you should see a small brass nut where the gas comes from. there is a small pinhole in the centre,mine was slightly blocked and this reduced the flow of gas. i cleaned this with a pin and the gas flow improved. i am not an expert and take no responsibilty if it goes wrong. it appears to have worked for me so the choice is yours.
regards. flask
Posted on Jan 14, 2009
  • 10 Answers
SOURCE: my oven isn't getting hot
Most likely one of the elements in the lower oven. For this job you will require basic tools and a multimeter to check the individual elements resistance.
This Must be done with the oven isolated from the mains supply Before beginning work.
remove the screws holding the element in place carefully pull a few CM's of cable through the holes in the oven bulkhead and disconnect the element from the supply cables.
With the element out check for short circuit and breakdown from Mains supply to earth. Using the multimeter on resistance setting check between the terminals and the outer casing there should be no connection here at all. any lower than 2M ohms is asking for trouble.
Check the heating elements by probing onto either end of the element and reading the result back as an example a 230V 2500W element should read around 21 Ohms. Elements are not repairable internally.
Posted on Feb 21, 2009
Richie_asg1
  • 1036 Answers
SOURCE: GAS JETS BLOCKED IN OVEN
If there is only enough gas for the pilot, it is very likely the main gas ciontrol valve is either in need of replacement or the "hot wire" sensor is in the wrong place or broken.
Basically the hot wire determines if the pilot is lit before turning on the main gas supply valve. It is a safety feature to dissapoint the suicidal.
I suggest this is fitted by a gas engineer as a leak at the valve can be very dangerous.
Posted on Feb 09, 2010
Hobs all working oven not working
Hob stopped working, oven still fine on electric cooker, any ideas ...
forums.moneysavingexpert.com/showthread.p...
MoneySavingExpert.comDec 25, 2010 - From this point, we'll assume that you are happy to receive all .... have a "problem" that covers the hob not working but the oven doing so. Gas Hob Ignition Not Working!
May 22, 2007
Oven not heating - Please help
Oct 14, 2006
Oven won't get hot - help please
Aug 24, 2006
More results from forums.moneysavingexpert.com
How to Diagnose a Fault With an Electric Hob ' eSpares
www.espares.co.uk > Advice Centre
Jan 01, 2016 | Logik LFTC60W12 White 60 cm Electric...
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
AEG Oven model D98000VF - error code F8 on display. All functions failed (no grill,ovens,hob)
I am pretty sure this is the temerature probe that has failed it can also be a failure of the main control board see how you get on but resubmit question if in bother.Hope I helped.
May 02, 2010 | Electrolux Ovens
Complete power loss to Hotpoint electric oven
You need to ascertain that the oven is actually getting power.To do this, you are going to have to remove it from the housing and remove the terminal cover where the the cable comes in, and check for power there.
You may find that the terminal block has charred due to a bad connection and the wire has burnt away
If this o/k, and you are getting voltage there, then the problem is obviously within the oven itself, could be a timer fault.
If you have no voltage at terminal block, then the problem is between the terminal block and the main switch.
Hope this helps with your problem.
Dec 03, 2009 | Hotpoint Ovens
Electric oven will not switch on. No heat, no fan. There is a timer display that is counting up and has the word AUTO showing. The gas hob works normally. How can I turn the cooker on?
Hi. You probably have to switch the oven onto manual control. Auto would turn oven on at a preset time. Is there a button with a hand symbol on it? This might be manual. Timer should show clock when in normal manual operation.
Aug 22, 2009 | Tecnik Ovens
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Jul 15, 2009 | Ovens
Hotpoint
just a thought - check the connection block where incoming mains connects to the hob. these quite commonly burn out
Sep 07, 2008 | Cooktops
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Hotpoint Double Oven ceramic hob
suspect more than one problem. half grill not working may be due to half the element gone open circuit. the other problems could be due to an installation fault. many ovens have links in the connection box which have to be tightened down. this is often overlooked. look at the connection box or terminal strip to check. there is often a diagram of hoiw it should be done adjacent.
Jun 02, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Kitchen Ranges Logo
49 people viewed this question
Top AEG Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you an AEG Kitchen Range Expert? Answer questions, earn points and help others
