Question about YouTube Videos
Openiong a pool toilet
My pool toilet has been off all winter- We did winterize it- Now i don't know how to turn it back on from the pipes in the basement
    Brigadier General:
  • 10,406 Answers
Probably, all you did was to turn-off the tap inside the basement, so that no water would be inside the pipe during the winter, and so there would be chance of water freezing inside the pipes, causing expansion, and creating a leak in the pipe. Turn the water on inside the basement. The toilet-tank should start to refill, immediately. If it does not, there may be another tap right beside the toiler. Turn that tap, too.
Posted on Jun 15, 2010
How to winterize my 15ft pool
Step 1. Go to your local pool supply store or go online to any of several pool supply companies
Step 2. Buy a Winterization Kit. Usually the smallest size kit is for up to 5000 gallons, which would be the right size for your 15' pool. The kit will be a little less expensive than buying each of the chemicals separately and will include instructions.
Step 3. Follow instructions on the Winterization Kit package (which will tell you what order to use the chemicals in the kit and how to do it).
Step 4. Be sure to drain your filter completely. Even after the filter has been drained, if possible move the filter inside where it won't freeze.
Sep 21, 2017 | Pool & Spa
How do i winterize my pool
Remove all drain plugs, open any valve you can and have. split apart any union, and depending on the part of the country you live in, the permafrost is a factor. If you freeze below ground, then you will also need to empty your pool down below the lowest inlet fitting and then blow the water out of the lines.
Once clear of excess water, plug the holes so rain water does not refill them!
  • heater will have 2-4 drain/winter plugs
    • also remove the pressure switch
  • pump will normally have 2 plugs
    • Open & remove lid from hair & lint pot
  • Pool sweep booster pump has 1 plug
Any low spots in the plumbing will trap water in them. Drill & tap a hole - 1/4" Normal pipe thread - that is the most common size of a winterizing drain plug. Others may just cut the pipe right at the lowest spot and glue in a union for future winterizing.
Mar 02, 2015 | Pool & Spa
Center pipe was cracked when we took it out to replace the sand what would cause this plus there was sand under the bottom cover
Typically, the cracking of internal filter tank components is due to freezing temperatures over the Winter season. You should always COMPLETELY drain all water from your filter and store it inside during the winter.
Another reason is over chlorination of your pool water and/or adding chemicals directly to your water thru the wall skimmer.
Aug 27, 2013 | Hayward SAND FILTER, PRO SERIES
How do i winterize it
They recommend using plumbers antifreeze or RV's antifreeze, flush it down the toilet and let it sit in the drain pipe so the pipe won't freeze. Also is a good idea to insulate the piping, this will also prevent it from freezing.
Sep 21, 2011 | Saniflo 002/005/007 Saniplus Toilet with...
How to winterize ? i have the jandy lrz model 125000 natural gas and what to know how to close down and winterize
turn off gas valve and blow water out with air then with RV antifreeze when you see antifreeze coming out its good see you tube video on pool closing
Oct 27, 2010 | Jandy Legacy LRZ 125000 BTU Millivolt...
Leak in heater after winter freeze
Yes you can just be sure to leave enough room to plumb it back in when your ready.
May 01, 2010 | Teledyne Laars Laars Lite2 Heater 400000...
How to winterize pop up camper 2007 fleetwood pop up it . this site won't let go any where except this car site so if you know how to winterize a pop up camper let me know
Any place that sells campers can advise you. I would disconnect the water supply line underneath the camper and open all faucets. This will drain the lines. Pour some antifreeze especially designed for this purpose in the toilet and in all sinks. Don't forget to flush the toilet and pour a little in the tank after you turn the water off. This will prevent the traps from freezing.
Oct 18, 2009 | 2004 Chevrolet TrailBlazer
How do you winterize?
pull the three (or so) drain plugs in your heater ... use a shop vac (without the filter in it) to blow and then **** out any remaining water.
hopefully, your pressure and suction pipes lead away and down from the boiler. Make sure you **** out those pipes as well.
You know how to drain your filter(s) and pumps ... right?
I hope this helps you
a
Oct 05, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
YouTube Videos Logo
116 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
