Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Poulan pro riding mower will not go forward or reverse
Check the square key on your drive shaft
Posted on Jul 20, 2010
  • rmdyjoe Mar 20, 2011
    I had just changed a flat. Saw this little black bar fall on the ground and wondered, what is this? It looked lilke an allen wrench but in an "I" shape not "L" and slid it in the hole/ledge where it fit and put back the lock on and abracadabra.....it goes into gear.
  • redneckfixit Jul 27, 2011
    it is called key stock. your mower has a hydrastatic transmission and if one side is missilg your mower will fail to run. the key stock locks your wheel to your drive shaft.. i bought one used and the previous owner could not figure out why it would start and run, even the deck would engage but the mower would not run. after taking the wheel's out i noticed that one side was missing key stock, i spent 80 cents and the mower ran great. hope this helps :D
5 Suggested Answers
  • 130 Answers
SOURCE: Poulan Riding Mower will run in neutral, not in forward or revers
you have safty switch on the mower one or more are bad there are three of them
win you put in reverse some mower will cut off this is a safty device on some mower
Posted on Jul 18, 2009
  • 4 Answers
SOURCE: Hard to shifet my poulan pro and wont go into reverse
Try loosening the belt tension to the transmission a little bit. Some of these are just stiff and you have to slip the clutch a little to rock them into gear.
Posted on May 25, 2009
  • 78 Answers
SOURCE: Riding mower surges in forward and not reverse. It
Ok first of all is not an automatic.Its a pedal operated transmission. The motion is accomplished by tightening a belt with a moveable idler and it is only shifted with a lever to forward and reverse. The belt probabley has a burnt spot in it and it hits that spot and it feels like a surge. Replace the motion belt
Mike
Posted on Oct 22, 2009
  • 33 Answers
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Posted on Apr 14, 2010
Ride lawnmower
bad check valve can do this also bad pump but i would say check valve is bad and chang hydrstatic oil and filter probably really dirty oil
Sep 01, 2014 | Poulan Garden
Not moving forward
the blades and the drive use different belts take a look at the drive belt
Apr 07, 2012 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan pro snowblower...engages in forward but not reverse
Fortunately I live in the south and have never had to work on a snow blower! Is the drive portion belt driven? If so, take a close look at them to make sure that they are not worn or streched. If it is hydraulic driven you will have a problem with the valve that diverts the fluid from forward to reverse. Let me know if I can help further.
Nov 27, 2011 | Poulan Garden
My 54" Poulan Pro riding mower dies when the
battery weak replace or charge, mower has electric clutch which pulls amps from battery
Jun 26, 2011 | Husqvarna 24HP 54" Yard Tractor ()
Jul 18, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
May 25, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan Pro riding mower jerks in forward and the blades engaged
This is a lawn mower catagorized as a chainsaw. We don't answer lawn mower questions ands you don't cut down trees.
Mar 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Mower bades
I have a 2007 pollan pro 19 hp mower that i have changed the blades on and they were not reversed threads righty tighty lefty loosey
Sep 26, 2008 | Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
2,566 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
