Question about Maytag Neptune MDG5500AW Gas Dryer
Switches to wrinkle release and changes to 18 on display.
When I start my dryer in either timed or ensor mode after only a minute or two it switches to wrinkle release and the number eighteen is displayed. It will also beeping intermittantly. Doe any one have same issue. Does anyone know how to fix this?
  • 1 more comment
  • JustinP Apr 24, 2008
    Tried that but it still keeps beeping and switching to wrinkle release and 18 on the display.
  • JustinP Apr 25, 2008
    I am not much of a tech guy here but we have been making the dryer work by holding down the sensor dry button. So I do not think the key is stuck but I may be wrong. As long as pressure is on either the sensor dry or timed dry button on the keypad the dryer operates fine. But once we stop pressing those buttons it switches to wrinkle release and 18 is in the display and beeps intermittently. I really appreciate you trying to help me, I am willing to try anything that I can. Is there a way of making the wrinkle button not work but the rest of the dryer to work? Like I said thanks.
  • JustinP Apr 28, 2008
    Jim,
    Yes the 18 is what comes up if you push the WR button, it is the time it runs on that cycle. I did take the cover off the back and saw what you are talking about with the ribbon wire. I found out how to run the dianostic feature on the unit and the 08 code comes up and it says that it is a stuck button. However when I run the membrane test none of the buttons show that they are stuck by flashing. I will say though that I believe that it is the wrinkle release button because whenever I unplug the unit for however long, it always shows 18 and wrinkle release on the display when plugged back in. Do you know how I can fix this? Is it expensive, is there a used parts place for replacement? Again I really appreciate your help.
    Thanks
    Justin
  • 145 Answers
Check the vent coming out the back. It may be plugged up not alowwing proper airflow. You might just unhook it for one load to see if that is the problem.
Posted on Apr 24, 2008
  • Anonymous Apr 24, 2008
    You may have a stuck wrinkle release key on the keypad. If you have an ohm meter you can check this be unhooking the power removing the control panel cover and unpluging the ribbon should be j7. Wrinklee is pin 11 to pin 15. There should be no reading until you push the button.
  • Anonymous Apr 25, 2008
    You can't unhook the wrinkle release key without unhooking other keys they share ribbon wire. I have look through the service info on your unit three times but wrinkle 18 is not anykind of listed error. If you just start the dryer hitting wrinkle release does it read 18?
SOURCE:
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
Periodically, the display will change to the wrinkle release mode from sensor dry mode (all by itself), and the timer will show 18 minutes remaining. If I switch it back to sensor dry mode, the display...
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing, if that is fine the problem is either the door switch or the control board. Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Maytag Neptune MCE8000AY Electric Dryer
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
Dryer cuts on run a minute starts buzzing loudly and shuts off then a little while later starts by its self
DOES THIS DRYER HAVE A WRINKLE GUARD CYCLE OR SWITCH THEN THIS IS NORMAL ASLONG YOUR IN A WRINKLE GUARD CYCLE ON TIMER OR WRINKLE GUARD SWITCH IS ON
Jan 26, 2011 | KitchenAid Dryers
Need trouble shooting proceedure to enter self diagnostics for maytag neptune
From the service manual there is more to it but that was all I could put here.
Accessing Service/Diagnostic Mode:
Pressing down the damp dry and time (-) keys
for 5 seconds places the machine in the
diagnostic mode.
SPECIAL TESTS
The following table lists the various tests
available while in the Service Mode, which
can be accessed by pressing the following
keys:
Press Keys Special Test/ Function
wrinkle
release Diagnostic Codes
dryer
temp(^ )
Sequences up the
help/diagnostic code list
dryer temp(v) Sequences down the
time (-) Displays Software Revision
Number
very dry(< ) View current cycle
temperature (Co)
start/pause
Start or pause cycle running
but remain in Diagnostic
mode
Accessing Diagnostic Codes
After the machine is in the diagnostic mode,
a ‘d’ will display and let the technician know
they are in the diagnostic mode. Pressing the
wrinkle release key will access the diagnostic
codes.The diagnostic codes can be viewed by
using the temperature (^) & (v) keys.
The down arrow key will sequence down the
list one each time it is pushed with no wrap.
The first time the down arrow key is pushed
the display will sequence to the next code
logged. The last code being displayed being
the oldest code. The up arrow will sequence
up the list one code each time it is pushed
until it reaches the top code. If there are no
diagnostic codes available, ‘00‘ will be
displayed for the diagnostic code.
There will be no multiple occurrences of
either a diagnostic code or help code generated
in the same cycle reported on the list.
But if the same code occurs in repeated
cycles, it will be registered.
To clear the diagnostic code list press
wrinkle prevent and very dry (>) for 5
seconds while viewing the list.
System Check Mode
While in diagnostic mode, pressing the damp
dry
and signal (+) keys for 2 seconds, will
put the dryer into the system check mode.
"SC" will display.
This mode will allow the various inputs and
outputs to be controlled and viewed by the
technician by pressing individual keys. If no
activity is seen for 5 minutes after a key is
depressed, the control will reset back to the
normal mode. If no further activity is seen
after an additional 5 minutes the washer will
turn off. The following table lists the various
functions based upon on keys being depressed.
Membrane Pad Check
While in system check mode, pressing the
damp dry and sensor dry keys for 5 seconds,
will start a membrane pad switch test.
The membrane check involves turning all the
embedded LED on the membrane pad on.
All the LED’s can be toggled off by pressing
the key associated with the LED. To exit the
test at any point, press the damp dry (>) &
sensor dry keys again for 5 seconds or press
the off key to exit diagnostic mode.
Key Pressed: Function Performed
sensor dry
Enable sensor dry circuit.
(sense dry LED) When short
circuit is detected across the
sensor bars the normal dry
LED will turn on.
start/ pause
Cycles the motor relay
on/off. When the motor is
running the start/pause LED
is on.
dry temp(^ )
If motor is running, cycles
the heater/gas valve on/off.
When the heater is regular
temp LED is on.
temperature (Co)
www.appliancehelponline.com
Mar 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I can not get it into service mode.
There is not a "diagnostic mode" for the neptune washer.
All tests and functionality are done at each setting using the timer (except the tach circuit)
What is the problem you are looking to diagnose??
Thanks!
Mar 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a Whirlpool Comfort Plus II Gas Dryer that when you press the start button, it will not start. I was running last night but when my daughter went to start on a new load of clothes, the dryer would...
Try the door switch and see if it clicks to activate. Also, make sure that the dial is always turned clockwise so as to not strip the teeth. Could be the timer .
Jul 05, 2009 | Dryers
Maytag Neptune Dryer MDE5500AYW beeping and resetting itself
Ok , I replaced the control board. Still beeps continuously. Just sitting there, nothing else is on, just plugged in......beeep,beeeep,beeeeep,WTF man? I am about to turn this damn thing into an anchor and invest in more clothes lines! Maytag sucks. MAYTAG an acronym for...
Maybe
All
Your
Technicians
Agree;
Garbage...
May 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Problem when drying gets to 1 minute mark
This is happening when you selected the wrinkle prevent option or you set it to wrinkle release cycle.what it does is it is tumbling with no heat to release the wrinkle in the clothing. This is normal.It could also be normal part of drying in "regular" cycle
May 29, 2007 | Maytag Neptune MDE6700A Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
636 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
