Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Wet section leaking
I have the origanal design master cool cooler with the coated wet section. I see the new ones have a removable plastic liner instead of being coated. My wet section is leaking as the coating has cracked. Will the removable plastic liners work in my older cooler, and these be purchased seperate?
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: I need a new water
You can find the parts here:
http://www.indoorcomfortsupply.com/Mastercool%20Plus%20Parts.html
I am pretty sure your going to have to order the wet section U pan for your model. (Item 19) / $249.95
Thanks for choosing FixYa,
Kelly
Posted on Apr 03, 2011
Used wrong water filter. Now that we replaced with correct filter, there is a horrible odor in the refrigerator.
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
Putting in the wrong water filter will not effect the smell in your refrigerator. At times the granules in a water filter will break down and get into your water dispenser and ice cube tray. This should not create a bad smell, just cloudy water.
Your plastic liner in your refrigerator has pores and holds odor. You have something in your fresh food section or freezer that is spoiled. Your fresh food section receives cooling air from your freezer. If you have a spoiled product in your freezer you will not smell it because it is frozen. But, as the cooling air goes into your fresh food section and cools down you will smell it.
Find the bad product in your freezer and discard.
With a 50% solution of white vinegar and water wash the plastic liner.
Now you can put a tray of baking soda in your unit, until you purchase deodorizers based on temperature requirements, one especially designed for the freezer section and one for fresh food section. These deodorizer are about $12.00 each.
Try Lowe's and Home depot.
May 11, 2015 | Samsung RF31FMEDBSR Stainless Steel 31 cu....
Model 610 - how do I locate the drip tray and how do I remove it? The power was lost after TC Marcia and products dripped in the fridge and freezer causing a terrible smell.
Hello;
Plastic holds odors. The smell may not becoming from your drain pan, but more likely the liner.
What to do:
1.) Remove the shelves, ice bucket and crisper drawers and scrub them with a baking soda base cleaner.
2.) Scrub the liner walls.
3 .) There are deodorizers especially made for refrigerators; One for the fresh food section and one especially for the freezer section. You can get these for any appliance store.
4.) Ok, lets check the drain pan.
a.) Unplug your unit or turn the main breaker off.
b.) Raise the two leveling screws in the front to allow you tp pull your unit out.
c.) Having enough room to get behind your unit, unscrew the bottom cover.
d.) Observe. You either have the terrible drain pan design, where the drain pan is fixed on the top of the compressor with hi-temp adhesive. Do not attempt to remove. Over time the adhesive dries out and the drain pan falls off.
The other type of drain pan is almost just as bad. You have to unbolt the compressor and other things to access. Do not attempt this.
What field technicians do when there is a drain pan leak, is repair the leak with duct tape and a high temperature silicone adhesive. In this case if there is an odor, sprinkle 1/2 cup of baking soda around the drain pan.
Feb 26, 2015 | Refrigerators
99 olds aurora washer pump or lower tank is leaking. Only info I can find to remove or inspect says remove passenger side wheel well but it's welded and not possible. Please help..
Inner wheel well or fender liner-- is what you pull
back, to get in there
Just plastic push pins & maybe a couple
of screws,then pull the plastic liner clear
Not welded
You can see & get to the top of the tank
to fill it,so you know where it is
Just get access from the wheel well
Best raise & support one side of subframe
& remove the one wheel
Use a screw driver on the two side slots ,in the push pin
heads, to pull them out (not all the way) then remove them
Nov 23, 2014 | 1999 Oldsmobile Aurora
Master cool not cooling. Outside air is dry and temp between 100 and 108. Fan working, water pump working. Water pan is full. Water flowing to top of padPad gets wet but only lightly. Air from cooler...
I would bet that the problem lies in what you said about the pad. It needs to be well-soaked for the evaporative effect of the unit to do its job.
You give no model, but if you disassemble the unit (only the top panel) at the water distribution tube and expose it you can see what's going on. Water flow will be minimal.
The tube disconnects from the water supply tube at one end.
Disconnect it and, carefully since it's plastic, clear debris out of the distributor.
If it's like mine, it will have a fair amount of scale built-up in it. Once clear, re-assemble and start the unit.
Jun 28, 2011 | Heating & Cooling
I need a new water Pan for my adobe Master Cool Model EC630G Master Cool Cooler????? Where can I get one, and how much for cost?
Kelly
Mar 01, 2011 | Mastercool 67680 Evaporative Cooler Air...
Need to know the difference between a master cool and a ultra kool
They are pretty must the same design, the Mastercool was made with heavier metal. But Mastercool are no longer being made,,,, so I guess if it's a new one you are looking for,,, Ultra Cool it will be.
Good Luck,
Paul
Mar 25, 2010 | Mastercool 67680 Evaporative Cooler Air...
1999 Pontiac Grand Am with "lower intake leak"...What does this mean specifically? Would this mean the intake for the radiator, gasket, or valve?
Usually intake has to do with the induction system, as in intake manifold , The intake manifold can have several types of leaks, the intake can have a vacuum leak, oil leak, coolant leak or a combination of any of the before mentioned....hope this helps,
Aug 30, 2009 | 1999 Pontiac Grand Am GT
I have a 97 Lincoln Continental. I am trying to replace the cooling fan. I have the shroud loose but can't figure out how to get out. Any help would helpful. Thanks
YOU NEED TO TAKE IT OUT FROM THE BOTTOM REMOVE PLASTIC SHROUD THEN DRIAN AND PULL LOWER RADIATOR HOSE FROM RADIATOR AND THE REST IS PRETTY SELF EXPLANATORY MAKE SURE YOU BUY THE CLIPS FOR THE WIRRING BEFORE YOU EVEN START
May 09, 2009 | 1997 Lincoln Continental
BAD INSTALLATION ON LG 4.00 WM2496H*M TROMM WASHER.!!!!!!!!!!!
The storage bottoms are ok in quality, and do give you more space. They are built for just the use of the washer/dryer they are made for, so they will hold up. Best idea, is when you get your base units, tell the store you want a new pan liner installed as well. You may also want to tell the store that the installation personel who set up your new machine broke the last one and you want some sort of credit, free delivery, new pan liner, discount, etc. All stores (Home Depot, Lowes, Sears, Ace) that carry plumbing products, appliances, etc, will carry a heavy duty floor pan for your unit. Good luck and let me know if you need further information. Jim
Nov 04, 2007 | LG WM-2277HW Front Load Washer
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
1,018 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
acrman404a
Level 1 Expert
Steve F
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
