Question about HP Pavilion a320n PC Desktop
HP Pavilion a320n PC Desktop - won't turn on
HP Pavilion a320n PC Desktop - computer won't turn on
  • 59 Answers
Please visit the link given below and follow the steps to resolve the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&cc=us&lc=en&dlc=en&product=364171
Posted on May 29, 2010
  • 313 Answers
Usually the power supply is bad if no lights com on...
Hp invent
Your computer may be poised to initiate a system restore
Jan 28, 2013 | HP Pavilion a320n PC Desktop
I have an hp pavilion a320n desktop and once turned on it boots through the bios and then stops leaving a cursor blinking in the top left corner
Have you tried your onboard diagnostics? Stop the boot process after your machine boots through the BIOS, with F12 (I believe) You want to get to the boot menu. There you should see diagnostics. Run that.
The other possibility is a bad hard drive. You can test it with the onboard diagnostics. The easiest way to do it is to get into your BIOS and have a look at your boot devices. Your hard drive should be the first device.
Apr 17, 2012 | HP Pavilion a320n PC Desktop
Http://nwn2.wikia.com/wiki/System_requirements <-- I have a HP pavilion a320n (upgraded to 2GBs of pc3200 ddr 333mhz memory I also have an ultra 32mb video board installed came with this PC) I was...
there is only one good answer!! for sure,,,, !
think now, and like NEXT week or in 6 months... see?
buy the best GPU card you can afford.,
i have a $100 card in mine can it runs any game.
top Nvidia. GTX-650 up. buyone.
and forget all that other ACER bs...
min card is
NVIDIA 6600+ or better (relic old card)
Mar 13, 2017 | HP Pavilion a320n PC Desktop
I have HP a320n PC. Max ram is 2gb I currently have 448mb of ram when I add two 1gb sticks the PC starts to reboot itself repeatedly, and starts to say there a problem and do I want to start in safe mode...
If you have 448MB of RAM, you started with 512MB of RAM, and the computer has "stolen" 64MB of RAM to use to interface with the video-card.
What happens when you remove the 512MB stick(s), and install just ONE 1Gbyte stick?
Does your computer work correctly, and show as 960Mbyte of available RAM?
It's possible that one of the RAM sticks is "bad". Test them in your computer, one at a time, rathre than both at the same time, to "isolate" the good/bad sticks.
Feb 24, 2011 | HP Pavilion a320n PC Desktop
On pressing power button blue light comes on for a split second then goes off and fan runs and CD drive and HD drive runs initially, pc continues to run but nothing on the screen. What might be the...
Bad Power Supply. Weak voltage power rail. Enough power to light LED lights, and spin fans, but not enough to turn the Processor on.
1) ALL of the LED lights on at once use less than 1 Watt of power
2) Each fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts. Depends on what Processor it is.
HP Pavilion a320n?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00039102&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=364171
Uses an AMD Athlon XP 2800+
(2.08GHz maximum frequency rate. {2083MHz actually}
Socket A processor socket. Socket A is also referred to as Socket 462)
Can use up to 68.3 Watts
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors#Athlon_XP_.22Barton.22_.28Model_10.2C_130_nm.29
Uses a 250 Watt power supply that is the > short ATX form factor.
Approximately 6 inches Wide, 3-1/2 inches Tall, and 4 inches Long.
You may be able to squeeze a full size ATX power supply in. Measure to see.
(6 inches Wide, 3-1/2 inches Tall, 5-1/2 inches Long {5.5 Inches)
Added specs,
http://www.premiumgeeks.com/desktop/hp/hp-pavilion-a320n-specs/
Part Replacement Instructions, (How to replace parts, and open the computer case),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&docname=c00039102&product=364171&
Click on >
Part Replacement Instructions (7.3M)
Computer on a table, unplugged from power, computer case open.
OBSERVE Anti-Static Precautions.
Also would advise using a can, or two of compressed air for computers, and cleaning the inside of the computer out.
Use Q-tips to dislodge the heavy 'Gunk', then use air to remove it.
Plus would advise removing the Ram Memory module/s ('Sticks'), and cleaning the gold plated contact pins on the bottom.
Use a pencil eraser.
If you are Not using a solid eraser, and the eraser on the end of a pencil, refrain from letting the metal band contact the Ram memory contact pins.
Remove the eraser dust with air.
You can use a can of air, or air pressure from your mouth will be sufficient.
For further questions post in a Comment.
Regards,
joecoolvette
Nov 28, 2010 | HP Pavilion a320n PC Desktop
My computer keeps booting over and over again even with everything disconnected and all the cards removed.
Your OS is at fault. Please re install windows. And to save your data you must install it in a folder other than c:\windows, ie, in c:\xp or something. Your data would be safe and can be searched for after the pc reboots.
Jun 27, 2010 | HP Pavilion a320n PC Desktop
Describe your hp pavilion a320n blue light Problem
then your motherboard is dead you will either need to replace the mother board or replace the whole computer.
Apr 20, 2010 | HP Pavilion a320n PC Desktop
What do I have to do to get my integrated video working again once I remove my video card I have a hp pavilion a320n
Once you remove your current Video card you may have to re-enable onboard video through your BIOS, if it was turned off in the first place. Usually it won't be turned off unless someone did it manually.
Aug 11, 2009 | HP Pavilion a320n PC Desktop
HP Pavilion a320n PC Desktop Logo
552 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
