Question about Briggs & Stratton Garden
I have a Murray Riding Mower won't start. I took
I have a 12 hp Murray Riding Mower won't start. I took off the filter and out a small amount of gas in the carb, It will run untill gas burns out. Then it goes dead and help would be greatly appreciated. And it is a Briggs&Stratton Engine.
  • Rick Smith
    Rick Smith Jun 08, 2010
    I did this and now it just pours gas inside the carb. It like it is just a free flow.
  • Paul Marks Jul 27, 2012
    howdie sounds like to me the float is stuck and needs some cleanin take the bottom of the carb theres a neddle with a pin slowy take the pin ut clean it put bk together and she should be good to go it just sticks wonce and awhile from use and age like the rest of us
  • 36 Answers
Clean fuel line and carburator out real well with a good quality carb cleaner this should do the trick,take the carb apart to do this check needle valve where gas comes in to the carb bowl it is alot of times plugged up
Posted on Jun 07, 2010
  • csurvivor58 Jun 08, 2010
    you have the float adjusted wrong the needle valve stays open and lets gas run in, you have to adjust the float so the valve shuts back hold the carb in your hand and take the other hand and raise the float to where the gas just stops then set the float there!
  • 20 Answers
Sounds like you need to take screw out from bottom of float bowl & clean holes out, this is an updraft type carb, if hole is plugged it will get no gas
Posted on Nov 10, 2010
Murray owners maual book 12.5 hp
mower was giving to me ,have not idea what the moder no is . i was told that its 1980 12 horse with 32" cut murray riding mower
Jun 07, 2013 | Murray Garden
12 hp riding mower rough idle stalling
You have a fuel filter weather external or internal. Replace it
Aug 26, 2012 | Murray Garden
Murray riding mower will not start. Bought and installed new Champion spark plug, bought and installed new battery. Had fuse checked and it is fine. The mower sounds like it wants to start but will not...
This could be several issues. The most common is gum from the gas building up in the carburetor. To eliminate this as a problem pour a small amount of gas directly in the Carburetor. To access this you will need to remove the air filter. while cranking the mower after doing this "feather" the choke a little. These carburetors get gummed up very easily if left sitting for any period. it could be a matter of bad gas in the tank or possibly water moisture from condensation causing the issue as that will settle to the bottom of the tank and stop the mower from starting. Look in the tank and see if you have what appear to be dark colored blobs in the bottom of the tank, if you do that is going to be part of the issue. If the motor starts when you pour gas in directly in the carburetor the problem is most likely a need to rebuild the carburetor or with the fuel.
Jul 23, 2011 | Garden
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray riding lawn mower
I have a 12 HP Murray riding mower about 6yrs old model 30577X8A. I am having trouble shifting it in and out of gears, ever thing runs just fine can you help?
Jul 04, 2008 | Computers & Internet
Garden Logo
555 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
