My scanner will not scan the black label insurance stickers from the post office. One of the scanners does all bar codes but this one does not scan the green and white "Delivery Confirmation" or the black insurance "200<".
  • 59 Answers
Delete the scanner from device manager. Unplug and replus the scanner to the computer. Try to scan as an image jpg file.
Posted on May 29, 2010
123scan - leanguage problem
http://www.motorola.com/web/Business/Products/Bar%20Code%20Scanning/Bar%20Code%20Scanners/General%20Purpose%20Scanners/DS9808/_Documents/_Static%20files/SYMBOL%20DS9808%20Quick%20Start%20Guide.pdf
there are bar codes for the country you are in underneth programing bar codes 3rd one down in the 3rd colom
if this helps you out pleazse take a moment to rate this. anything else i could assist you with?
Jan 14, 2013 | Symbol DS9808-SR00007NNWR - Motorola...
Tip
How do I troubleshoot a Symbol Barcode Scanner?
<p>Barcode Scanners Symbol read and translates the barcodes on merchandise. The scanner translates the bar code symbols on the label says the price of the item and merchandising information. Traders use the symbol bar code scanner to identify their merchandise. A programming error in reader bar code symbol will cause confusion and may lead to loss of money. Troubleshooting barcode scanner symbol allows you to identify bugs and find solutions to errors. <br /> <p><br /> <p>1. Remove the installed fonts from the reader bar code symbol. The sources of such capacity to disrupt the functioning of your bar code scanner. Press the "Menu" button on the scanner bed and press the "Select" option when the source is highlighted. Press the Delete button to remove the sources of the sample. <br /> <p><br /> <p>2. Close the bar code scanner Symbol with a source of energy. The scanner has a power cord can plug into an outlet. If the scanner runs on batteries, the battery is fully charged before using the scanner. <br /> <p><br /> <p>3. Move the scanner closer to the bar. The symbol bar code scanner cannot calibrate the bar if you wrong position. Place the scanner directly over the bar and wait for the scanner to read and transmit the code. <br /> <p><br /> <p>4. Wait until the bar code scanner symbol to complete the boot. The symbol bar code scanner is initialized when the USB cable is connected to the computer. Initialization requires a short period of time to complete the process. Let the bar code scanner symbol to be idle for 4-5 seconds before you first scan an object. <br />
on Jun 26, 2011 | Computers & Internet
Voyager MS9540 scanner...how do I enable code 93?
Go to www.honeywellaidc.com and click on English under North America. In the search bar type in 9540. You should only get one result for Voyager 95X0 Series of Single-Line Laser Scanners. Click on the heading and under the picture on the tab bar choose documents. Under user Guides choose MetroSelect Single-Line Scanner Configuration Guide. On page 14 you will find the barcode to scan "Enable Code 93" . Page 14 is also labeled as 2-6. Good Luck
Oct 01, 2012 | Metrologic Instruments MS9540 Voyager...
How to scan
Step #1 - Have the printer powered up and plugged into Mac.Step #2 - Open "System Preferences" and the in the "Hardware" selection select "Print & Fax".Step #3 - Drag down the menu bar on the left side until you reach the bottom were its labeled "Scanners" Step #4 - Select the scanner that you want and began scanning.
Jan 15, 2012 | Canon PIXMA MX330 Office All In One...
What software can I purchase so I may make barcodes with a Voyager Honeywell scanner.
Microsoft Excel can print bar-code labels. I did this for my office for our stock room and they work with every bar-code reader I've used so far.
Apr 22, 2011 | Honeywell MS9540 Voyager Hand Held Scanner...
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
Automatic RETURN/ENTER ...
I set scanner to defaults and had to Scan Bar Code labeled <DATA><SUFFIX 1> on page 4-50 of LS 2106 Product Reference Guide to set return after scan.
http://www.intermeccorp.com/pdf/2106setup.pdf
May 13, 2008 | Symbol Hotshot LS2106 Handheld
Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Aug 16, 2007 | Metrologic Instruments 9520 Voyager
44 people viewed this question
jasbo
jasbo
