Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I just bought a factory refurbush 18". It runs fine for about 5 minutes than sound like it needs gas, than dies!!! I have to wait about an hour to start it and play this tune again. Any ideas?
  • 468 Answers
This is a carburetor tuning issue. As those carburetors can be really touchy, I'd try to take it back and have it exchanged.
Posted on May 29, 2010
I have a 1989 Ford f150 drive for about 30 minutes it dies out or stop and want crank for about an hour
I would unplug the gas cap when it stalls; if you hear a hissing sound, change the gas cap, because it builds up a vacuum in the tank.
Old story??
1989 F150 dies when running wont start back for about 10 minutes ...
www.f150online.com/.../492401-1989-f150-dies-when-running-wont-st...
Nov 29, 2013 - Have a 1989 F150 with 5.0 bought truck about a month ago from original owner with only 89K on it. ... Took me about an hour to do a normal 15 minute drive, died and cooled about 5 times. ... Vehicle: 2003 Ford F150 ... It was cold when I put it on and after putting it on, started and drove for about 30 minutes ...
Sep 18, 2015 | Ford Cars & Trucks
My car is sputtering and dying. If I try to restart it, it will immediately go into sputtering/dying mode. If I wait a while an hour or so it will start up and drive fine.
When was the last time that the carburetor was stripped and cleaned? Also have you checked the fuel filter? Finally, the problem seems to come and go as the engine is run (and it gets hot) check that the fuel line and any electrical cables are well away from the hot engine as far as is possible.
Jun 16, 2015 | Cars & Trucks
Seadoo jetski
have you got any fault codes on the screen ? has the intercooler been checked for leaking in to the intake manifold ? press the set button 5 times to see codes if any ! how old is the fuel ? over 5mths then replace !!
Jun 20, 2013 | Boating
Engine stops running
if it was a bad gas or water in the gas the car would not start and if it does start it would run really rough it sound to me like you have an over heating problem doe s the temp gauge say its over heating just before it dies?
Oct 01, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Pickup runs fine when cold 5 minutes later spits and sputters and dies wait a minute starts up runs good for 30 seconds. then dies again
A common problem with Ford products built in the 1980s is the ignition module mounted on the distributor.
You will need to figure out if it is a fuel problem or ignition problem to proceed.
Jul 01, 2012 | 1987 Ford F 150
LTX 1000 craftmans rider 18 hp ohv kohler rpm fluctuates, then dies. I let it sit for ten minutes and then start it and mow for a few minutes and then it does the same thing. is there a safety cut out
There could be some type of contaminate in your fuel/lines. Check for that!
Then check your fuel filter. and hoses.
Your carb needs to be rebuilt!
May 26, 2012 | Craftsman Garden
I have a 345 e Series 18" (I think it's 18). It's a couple of years old and probably no more than 3-5 total hours usage. Normally starts and runs perfect. Today it won't run, seems to be starving for gas....
If stale fuel has been left in the saw then try draining the tank and re filling with fresh fuel, also hook the fuel line out of the fuel tank and replace the filter on the end.
Apr 15, 2017 | Husqvarna 18" 502cc Prosumer Chain Saw ...
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Chainsaw starts and runs fine for a few minutes
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
Jul 26, 2009 | Garden
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
163 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
