Question about Nikon COOLPIX L4 Digital Camera
Lens error is displayed on nikon coolpix L 4. what do I do?
  • 1,170 Answers
Here are a few possible fixes :
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra power to help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one). Some people also have actually used a "Shop Vac" with this fix to help extend a retracted lens.
Posted on May 29, 2010
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
Nikon S220. Lens error. Turns on but displays lens error only.. Cannot take pics
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 15, 2010 | Nikon Coolpix 2200 Digital Camera
NIKON COOLPIX
The Camera displays lens error only when it's unable to retract or expand. This usually happens when the internal Hardware that controls the lens fails or any dust particle settles around the lens. In this case, just give slight bumps to the Camera against your palm. If the issue persists then service will be required.
Dec 01, 2009 | Nikon Coolpix 5700 Digital Camera
I got sand in the lens of my Nikon Coolpix L14
Take it in to be serviced. Or junk it and get a new L20 or something similar.
Jul 07, 2009 | Nikon Coolpix L14 Digital Camera
Nikon coolpix l2
I had this issue and I read on the net to hold the lens down on a table of some sort and apply slight pressure while pressing the power button, it should go right back in, It did for me!
Jul 29, 2008 | Nikon COOLPIX L12 Digital Camera
System error showing up on Nikon coolpix 3200
A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
1. Use the memory card that originally came with the camera (or a Nikon approved card)
2. Remove and replace the battery
If the error is still displayed, contact Nikon's Service Department (below). If the above tips do not help the camera must be sent to Nikon Service, there are no user serviceable parts on Nikon Coolpix cameras.
Jun 13, 2008 | Nikon Coolpix 3200 Digital Camera
Sytem error 10
Hi - I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Sort of like a Windows Restart to reset the memory.
Hope this helps.
May 09, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon coolpix 4600.
Hi I found this info on the Nikon Australia website:
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
Apr 29, 2008 | Nikon Coolpix 4600 Digital Camera
Lens is stuck open says lens error nikon coolpix l6
when the camera is turned on it displays "lens error". I can't take a picture and i can't access my pictures on the camera.
Apr 29, 2008 | Nikon COOLPIX L18 Digital Camera
Lens Error.
nikon coolpix 4 lens error help!
Nov 11, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
133 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
