Question about Asrock 775i65GV Motherboard
Motherboard if i turn on system no display no beep the cpu fan is working but no display
Hai i lost my motherboard CD how i can get to load in computer when i am dong format my computer.can u give any suggiestions to me byeee
Posted on May 11, 2008
    Problem Solver:
  • 5 Answers
Something is wrong with the power supply.. there might be a blown out mosfet
Posted on Apr 30, 2008
SOURCE:
On board led indicators are red in motherboard TF7100P-M7 power supply works cpu fan works both fans of the CPU heat sink assembly and power supply fan spin It shows no display, No beep
remove all ram memory wait 5 min,make sure to unplug from a/c,reboot with no mem should hear beeping unplug reinstall mem should boot ok if mem good,good luck!
Jan 08, 2011 | Biostar TF7100P-M7 Motherboard
If i turn on system no display no beep the cpu fan is working but no display
hi
try to 2 steps
one remove CMOS betters from your motherboard then remove your RAM keep for 10 mints then re fix
parts hope fully it will work
Oct 20, 2010 | Computers & Internet
Everything was working fine, then one day I switch...
Try to check your CPU unit it maybe have a power when you turn it on. Or just check their power suppy at the back when it works. If you check that all and it works normal just check inside your computer and try to see the Power LED (Light Emiting Diode) of the motherboard if have a light. Because if it is have a light your motherboard is good and if it is no light in the Power LED of the motherboard that was damage. But if your motherboard does not have installed Power LED try to check the CPU Fan it maybe works properly it because the CPU Fan was conncected in the motherboard if did not works the motherboard is also damage and need to replace. But if the CPU Fan was working properly, try to hold the CPU Heatsink if it is very hot the damage is your micro processor.
May 20, 2010 | Intel D945GCNL Motherboard
Cant get computer to
Disconnect everything from the motherboard except the power supply, CPU and power switch.
Turn on the computer. You should hear 3 beeps because you removed the memory.
If you don't hear any beeps, check the power supply. Check all the connections. Did you connect the 4 pin power? Did you skimp on it? A common mistake is to get a cheap, high-power supply. Just because the box says it's 1000 WATTs doesn't mean that will carry a steady load.
Still nothing...
It's either a bad motherboard or processor. If you have another processor that is supported on that board and you know it works, try it. If it boots return your CPU for a good one.
Unfortunatly, if it doesn't boot with a known-good processor that just proves the board is bad; it doesn't prove your CPU is good. You may have more issues.
Mar 08, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
I have a mecer computer, LGA 775 motherboard asus and the problem is the computer turns on when switching on and there is no display it beeps non stop . CPU and power supply fans are working ,lights goes...
continuous beeping is Power supply, motherboard, cpu, or keyboard problem. somecases it can also be the memory.
start with the memory then cpu and powersupply and finally motherboard.
let me know if the beep code changes as you change components, count the short and long beeps.
Jan 07, 2009 | ASUS P5VDC-X Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
Beep sound when swith on
good day,
a beep from your cpu system means that there is an error. and since there is a "cpu overheat" error, it could mean that your cpu cooling system (or its fan) is not working.
the shutdown is a defense mechanism of your cpu in order for your cpu not to self distract.
have the cooling system replaced as soon as possible to avoid further damage.
i hope this will help
Oct 13, 2008 | Intel D845GVSR Motherboard
CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Sep 27, 2008 | Asrock 775VM800 Motherboard
Motherboard problem
If your cpu fan is faster,it may be due to a higher frequency setting.
The frequency that it runs best at is 60 hz, but it can be running at 70 hz or higher.
Jun 14, 2008 | ASUS P4P800-X Pentium Motherboard
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
Asrock 775i65GV Motherboard Logo
93 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
