Question about Dryers
Dryer will not heat
Hello, My dryer will not heat up. It runs good but no heat.
  • 5,911 Answers
If the dryer turns on, drum spins, but you have no heat, any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If there is no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two RED leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set.
I hope this information is helpful to you. Post back with comments if you have any further questions.
Posted on Apr 08, 2008
  • Jeff Rockwell
    Jeff Rockwell Apr 09, 2008
    Thanks for Trying? The last line I wrote said to post back if you have any further questions. Have you attempted any repairs? Have you solved the problem yourself? Feedback is useful in these forums, because it helps the technicians provide better solutions. I gave a pretty in depth overview of what can cause a dryer to run but not heat. This was the best I could do with the one line question you provided. You listed no manufacturer name or model number to base any other information on.
Dryer runs but no heat. My husband is pretty smart with appliance fixes. Do you think that this thermal fuse solution would be easier enough for him to fix or should we get a repairman?
The thermal fuse is not going to be the problem...when the thermal fuse has gone out the dryer will not start so since it runs the thermal fuse is good. The number one thing that is wrong with a gas dryer when it doesn't heat is going to be a broken igniter,this tip i wrote explains what to check when a gas dryer doesn't heat http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 12, 2011 | GE DBXR463GD Gas Dryer
The dryer runs when started but does not heat up at all.
Hello and good morning. You dryer need a new heating elements. GB...stewbison
Sep 12, 2011 | Whirlpool Inglis IP8200 Dryer
My one year old samsung dryer runs but does not heat - air flow is good. Any ideas
Hello- The usual cause is a bad thermal fuse or heating element. Unfortunately you will need to have a Tech out to look at it, these aren't that easy to take apart and check. Good luck, best regards.
Sep 27, 2010 | Samsung DV218AEW Electric Dryer
Dryer runs but no heat. changed thermal fuse and still no heat. what else could it be and how do i get to it. i have a kenmore model #11070802990
hello 1 of the heat sensor could be faulty these sit behind the element usually right the back of the dryer there may be 2 of them if so change them both good luck
regards
shaun
Aug 03, 2010 | Kenmore Dryers
What do I do if my dryer runs, but does not heat?
Hello my name is Heath the problem is probably a bad heating element. If the dryer runs but does not heat then the heating element is bad and will need to be replaced.
Apr 07, 2010 | GE DDC4400S Electric Commercial Dryer
Whirlpool dryer model LGQ80000JQ4 starts to heat and runs then stops heating, but rest of dryer seems to run fine
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Sep 18, 2009 | Whirlpool LGQ8000JQ Gas Dryer
Hotpoint CTD40P tumble dryer only runs cold.
hello check the heat sensors first good luck
shaun
Aug 04, 2009 | Dryers
Dryer runs but does not dry my cloths.
Hello, If the dryer appears to be running ok but will not heat you probably have a bad heating element or switch. Usually the heating element.
I hope this helps
CYA Gator241
Feb 09, 2009 | Maytag PYE2300AY Electric Dryer
Function clothes will not dry, no heat
Hello, A dryer can have no heat for a few reasons, the first thing to check are the breakers or the fuses in the fuse panel. If one fuse is open the motor will run but there will be no heat. If this is not the problem I need more details (make, model# etc.) Thanks good luck
Dec 27, 2008 | Kenmore 63942 Dryer
Dryer wont heat up
1st I would check my breaker or fuses to make sure I was getting the correct voltage to the dryer.
2nd I would check the thermostats for continuity
3rd I would check the heating element. Check for continuity and to ground.. If it reads good but reads to ground you still have a bad heater.
One of these would cover about 98% of dryer repairs when the symptom is not heating. If you find that all of the above are good and still no heat. You may want to have a service tech look at the dryer. You really dont want to guess at parts like timers. It can get expensive fast. Good luck and happy fixin. mca0824@aol.com
May 02, 2008 | Hotpoint NBXR463EBWW Electric Dryer
Dryers Logo
128 people viewed this question
Top Dryers Experts
