Question about Garmin StreetPilot c340 GPS Receiver
Garmin c340 does not turn on
Read previous solutions and i am wondering ---exactly how do i charge the garmin with my computer. Exactly how do i hook it up. please step by step directions. thanks!!!!!!!!!!!!!!!!!!!!!!!!!!
    Problem Solver:
  • 5 Answers
Juts connect it to your PC with the USB cable and leave it for 10-12 hrs. It shoud charge
Posted on Apr 08, 2008
My Garmin c340 turns on then shuts off even when plugged in
I have the same problem. I have had it for only 4 months.
Jun 23, 2008 | Garmin StreetPilot c340 GPS Receiver
How to take Garmin GPS apart?
The front bezel, the silver grey plastic piece with the Garmin name on it will lift off.  Use a fingernail or a very thin tool to pry and lift it up.  Behind that are 4 phillips head screws.  Remove those and it comes right apart.  Look at the board on the top before taking it all apart to see exactly how it goes back in, it's a tight fight and has to fit just right.
Jun 20, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
Dead Garmin StreetPilot c340
The battery usually has a small charge when arriving from the factory, but it can die before it is received. You should charge this by plugging it into the car or the computer.
Garmin C340 GPS - Will Not Power On
Thanks. This helped me fix the problem.
Apr 02, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 FROZE? Here is how to fix it!
My garmin shuts down immediatly when I switch it on. Dont know if there is an internal battery that needs to be replaced or some thing else.
Jan 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 does not charge
I came here looking for solution and tried the "press eraser in bottom right corner and turn on" but didn't work for mine BUT if you look at the face plate (the part on the front that says "Garmin",) just under the word "Garmin" you see a small indent in the plastic, useing your finger nail, gently pull upwards and the face plate will come up. Also, be gentle while pulling the face plate being careful not to break it. ( I advise that you use your nail and not anythng that might scratch the plastic if you are intending on returning the unit, cause they may suggest that you tampered with it and that "voids the warrenty") Anyway, look at the USB plug (above the ON button on the side) and you see a tab, press it and the unit will reset.
Seems to me that with all the problems Garmin has had with their units freezing up that I should have found this solution on the garmin site! To think that there are people who will throw there unit away because of this problem OR who will pay 150.00 bucks to get it fixed through Garmin.
Jan 15, 2008 | Garmin StreetPilot c340 GPS Receiver
Charging
From a complete drained battery it took me about 2 hours of charging via the USB cable hooked up to my computer to fully charge it.
Dec 26, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin c340
Will the device turn on without the cord (on battery power)? If not then the cord is not the issue most likely. To make sure, you can use the USB cable and try charging via that hooked up to your computer (make sure computer is on). Give it sometime to charge (30mins) and see if you can get it to turn on. If this doesn't work, I think the next best thing is to contact Garmin support.
Garmin 340 streetpilot won't even turn on?
I had the same issue with mine during a trip. Probably needs to be reset. See page 31 of the users manual on Resetting your c340. Once I did this it worked fine.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Nov 28, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
324 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
