Question about RTO Atwood DSI-RV Water Heater-6 Gallon
Circuit board not getting power to e.c.o. G6A-7E Hot water tank not turning on gas checking parts, circuit board has power,getting power to thermostat side but not to eco side.ECO turns your gas valve on right? ECO reads open as well as thermostat. Thanks
  • 12,061 Answers
Hi, well it basically works like this, we have the Power coming in on the PHASE, now that goes to ONE of the Pair of NORMALLY CLOSED "Contacts", the "Hot Side" on a Thermostat, then from there the PHASE continues on, through the other contact, on the "Cold Side", to the ELEMENTS "HOT Side" and then across the Element the NEUTRAL. Thus the Circuit is complete. Have a look below for a rudimentary circuit. So troubleshooting is pretty easy as you can see. You simply need to check, if you have Voltage, at each successive point, working to the element, many times it is the Thermostat, as you can see that controls everything, BE CAREFUL. circuit board not getting power to e.c.o. G6A-7E - bca8dd9.gif
Posted on May 30, 2010
  • ted_willi490 May 30, 2010
    Had power going through thermostat to circuit board no power out of board. Bad board the problem for further reference. Thanks for your time. Ted
Water heater flame problem
Check your exhaust, see if its clogged or blocked, clean the flame sensors, I that does not work, then your gas valve is starting to go bad, there is a cap on it if you take the cap off you can turn the gas flow down a little bit,
Jul 14, 2013 | RTO Atwood Water Heater - 6 Gal LP
!990 Bounder By Fleetwood Water Heater is not lighting the propane
Check the gas line orifice for a spider web. Its possible the gas is not able to get past the web.
Nov 30, 2012 | Atwood Mobile Products Llc Water Heaters...
G6A-8E Water Heater will not start.
x8h3rkvosvawaaaaabjru5erkjggga=
You may need new circuit board, call mfg they may offer more help in determining if a new board is needed.
Good luck
Oct 28, 2017 | Atwood LP Gas Water Heater 6 Gallon 96121...
I have an Atwood water heater G6A-7E, heater heats up but no hot water flow after 15 seconds...Flushed system with water and air, put water to it and the hot water flow stops after a few seconds....
First check that any by-pass valves are in proper position. Remember, cold water has to enter in bottom fitting at back of tank, and hot water comes out at top fitting. Thus any valves that may be there, need to be in open position, and any valve between those 2 lines will need to be closed. If all valves are in proper position and working as they should, I would suspect you have a faulty check valve between top (hot) line fitting and tank. One easy way to check that before replacing it, would be to shut incoming water source off, whether running off pump or hose attached outside. Then relieve all pressure in system by opening taps until all pressure is gone. Now, go outside and open pressure relief valve carefully ( in case it's hot ) and make sure pressure is relieved there as well. Now, carefully hold pressure relief valve open while you have someone turn water back on, and see if you get good flow from pressure relief valve. If you get good pressure coming out of there, that tells you your tank is getting full, and you have water coming in as needed, so problem has to be on hot side ( top fitting ) and/or onward from there, which would be check valve fitting at top next to check. Remove the check valve and If you don't have a new check valve to try it, just put a short galvanized 1/2" pipe nipple in there for now if needed and that should do it, just attach your fitting directly to nipple. Before you do this, make sure you have removed all aerators etc on taps that may be plugged and tested pressure that way as well just in case. I have seen all of them plug up at same time before. If you remove them and get good pressure, then problem solved.
Nov 06, 2011 | RTO Atwood Water Heater - 6 Gal LP
I would like to know the electrical requirements.( voltage and amperage) Does it plug in or is it hard wired? If the power goes out is the hot water also out? thankyou
Are you asking about tankless gas or tankless electric?
You posted under Tankless gas water heater: gas type tankless plugs into standard 120Volt household outlet to power circuit board. You need larger gas line than used for tank-type gas water heater.
If you are asking about volt and amp draw of Tankless electric, then that depends on specific model number.
For example, if each tankless element draws 3500Watts, and unit has 3 elements, you will need 3 additional 20 amp 240Volt circuit breakers. Volts x amps = watts. 3500 watts divided by 240Volts = 14.58 amps. At full blast, this unit would draw 43.75 amps and will cost more to operate yearly than tank-type electric water heater. If unit has 4500 watts elements, then it will draw 56 amps at full blast, and use a good percentage of household power.
Tankless water heaters have no hot water in power outage. This is true for gas and electric models.
Additional resources:
http://waterheatertimer.org/images/Compare-water-heater-parts-650.jpg
http://waterheatertimer.org/pro-n-con.html
http://waterheatertimer.org/pdf/Bradford-White-on-demand-tankless-service-manual.pdf
Aug 04, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Atwood Water Heater G6A-7E, electronic ignition. Should after the water is heated a small flame is still present at the orifice. It is like a pilot flame. I thought that the electronic ignition was to...
You are correct, there should be no flame after it shuts off. Pull the + wire off at contacts as well and see if flame remains, if it does, the gas valve is faulty (leaking by) and should be replaced.
Jul 21, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have an Atwood G6A-BE model )or possibly G6A-B8) hot water heater. When I throw the starter swith on from inside the RV nothing happens at all. No spark. Nothing. Their is a light next to the switch that...
First of all, regarding propane side not lighting. Try shutting switch off, and go outside and remove the connection(s) from the circuit board, and re-install them a few times to see if it's just a bad connection (corrosion) that will correct itself by removing and re-installing the connector(s). If they appear dirty, use an eraser on end of a pencil to clean the contacts on the circuit board, and perhaps some WD-40 or electrical cleaner on connector, and try it to see if that helps. Keep in mind that the propane part needs 12 volts DC (battery or converter) in order to work. The light at the switch tells me you did have it at one time anyway. Try shutting it off and retry, as well as check for any fuses that may have blown.
One the electric side, I'm going to guess it's a "hot rod" or similar. Obviously you need the circuit breaker on that powers that. (hydro) You should also find a thermostat, probably by looking at rear of tank from inside RV, that will probably have a red reset button in the middle of it. Be sure to shut breaker off before you go poking around that thermostat, so you don't get a shock, seeing how we have no idea exactly who or how it was installed. If you determine that the hydro is getting to the hot rod, but still no hot water, then the element, or rod itself has probably burned out. Personally I'm not a fan of those, but if it serves the purpose, that's up to you. Just be sure to pay attention to any plugs and wiring in the circuit, and watch for signs of them getting too hot, such as discolored connectors, or melting wires or even signs of overheating if it's just plugged in to a receptacle.
Feb 16, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a G6A-7E electronic ignite water heater.
Make sure propane is on and getting to your stove burners ok, first, then try switching it back on. If it fails to ignite, shut switch off and try a couple of times, if still no ignition, get back to me.
May 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
Atwood g6A-7E wont turn off keeps heating water till tmp drips
Some dripping at pressure relief valve is normal, but are you saying it continues to run excessively hot? Does water in trailer feel extra hot?
The ECO, and/or Thermostat, should cut the power/flame before it gets too excessive.
Apr 03, 2010 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
105 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Donni Steen
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
