Question about Northstar Pressure Washer 3000 PSI
Work Force 163cc OHV
For the Work Force 163cc OHV what type of gas is used? And oil?
ProForce PWC102350 2,350 PSI 2.3 GPM 163CC MagnaForce Gas Powered Pressure Washer will not start
If you have compression then the first thing you check is for spark. If you have spark then you move on to the fuel system. You will have to pull off hoses at a couple of points to see if gas is at the carb and further along. If it is the carb then a simple carb kit will work.
Apr 13, 2014 | ProForce PWC102350 2,350 PSI 2.3 GPM 163CC...
Air in crankcase
is the oil over full ??? then i would suspect a crankcase breather issue which should be in the valve cover... then I would be looking at a head gasket issue, rings or all of the above
Dec 28, 2013 | Honda 8 HP Engine
Toro 621 snow thrower won't start
could be a number of things , spark , bad gas oil mix clean plug close choke when starting open after start , umber one problem clean the tank out
Dec 15, 2013 | Toro Power Clear 621 ZR 21 163cc Single...
I have a huskee lt4200, engine is a 420cc OHV.
Check for gas contamination in the oil....if the oil itself it gas free....its likely a blown headgasket.
Aug 05, 2013 | Briggs & Stratton Garden
Gas in crankcase and oil
The best solution I have found for this is to turn the gas shut off valve off when not in use. I have many of these Honda motors and on all of them if you don't close that valve after use, the crank case will fill with gas.
May 09, 2013 | Honda Horizontal Engine 8 HP OHV 2:1...
How much oil in ryobi rpw 2400 power washer engine?
they take from a half a quart to a full quart
Aug 10, 2012 | Garden
Oil leakage from ohv into air filter box
Check for a clogged PCV valve or disconnected...usually located on the OHV cover...Hope this helps.
Jun 25, 2012 | Cars & Trucks
Oil blowing out of carb. gas in oil ohv engine
carb needle valve stuck open clean carb possible bad float dont run with gas in oil
Jun 23, 2012 | Briggs & Stratton Briggs Stratton Intek V...
What type of oil do I use in my 6HP lawnmower?
Straight 30 weight oil is best, but a 10-30 will also work...
heatman101
Jul 17, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Northstar Pressure Washer 3000 PSI Logo
505 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
