Question about BenQ FP71G 17" LCD Monitor
BenQ FP71G+ screen blank
El... Great post in one of the forums describing how to check whether the monitor problem is with the inverter board (or the bulbs) or with the panel itself (the idea of shining light onto the panel).
Any suggestions on how to find out where the problem is on the inverter board?
  • 1 more comment
  • Spermy May 26, 2008
    Monitor will sometimes just lose picture while green light remains on.
    Can be sometimes be solved by unlugging the power cable for 20 or so seconds and plugging it back in.
  • Anonymous Oct 27, 2008
    i had the same problem. future shop wasn't going to fix it till i told them that it was their responsiblility. now our second one did the same thing. and we are taking it back tonight. thank goodness i kept my receipt. it didn't cost a thing to get it repaired. and it was the inverter board.
  • Anonymous Oct 29, 2008
    I have the same problem, but when I extend my display to this monitor (as a second) and Apply, for a brief moment the screen is displayed, although dim, and then it goes blank. I tried unplugging it and reconnecting the power with the same problem. Is this also characteristic of this problem?
    Champion:
  • 220 Answers
If front power led is on and No display ,Problem is with Inverter circuit.The post u descibe should help you determine with certainity that Inverter is the issue.
Samir
Posted on May 08, 2008
SOURCE:
My BenQ FP71G powers on and off, repeatedly, by itself no matter whether connected to computer or not. Everything else is fine. Sometimes it stays on for a minute or so, but usually for just a few...
my BenQ FP71G 17 in goes on after hundreds of times pushing on off switch and when it's on it does not go off, I have checked the on/off switch which is working oke and when the moniter is on the auto adjust message (brightness and contrast)pops up frequently and the screen adjusts itself.
Oct 12, 2010 | BenQ FP71G 17" LCD Monitor
My BenQ FP71G Monitor has been turned off for 2 weeks on starting it this morning I have fine colored lines that cover 1/3 of the screen on the right hand side.I have checked the cables. Have you any...
You have failing LCD panel or the 5vdc feeding the panel may be bad. Check to connection at the LCD panel T-CON board.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Aug 06, 2010 | BenQ FP71G 17" LCD Monitor
Where can I buy a logic PCB for FP71G Benq
Shenzhen VIIV Technology Co., Ltd is an expert at PCB,PCBA and Rigid Borad manufacturer based in shenzhen China.
MSN:[email protected]
Yahoo: viivtechavril
SKYPE: viivtech
Mobile: 86)15989403359
Email:[email protected] ,[email protected]
Website :www.szviivtech.com
Tel: 0086 755-29477736
Fax: 0086 755-29410695
ADD: sha
Jul 13, 2010 | BenQ FP71G 17" LCD Monitor
Monitor stopped working, blank screen powerswitch on green light. Was having intermitant problems going blank once in a while
First place to check will be the power supply section, look for bad caps (bulging top/bottom), post back what you see so we can guide you further, see example of failed monitors due to bad caps, lamps: http://s807.photobucket.com/home/budm/allalbums
Feb 05, 2010 | BenQ FP71G 17" LCD Monitor
No image on the screen when I turn it on. It is a BenQ71G
If the screen is black (ie there isn't any backlight) then the fault maybe the inverter board that supplies high voltage to the CCFL lamp ot the CCFL lamp is faulty.
For service, parts and DIY info. check out LCD Parts - use this link to their WEB site.
www.lcdparts.net
Sep 27, 2009 | BenQ FP71G 17" LCD Monitor
Benq inverter board schemtic
Post me a picture of the board and I might be able to Help.Normally transistors 2Sc5707 are defective.
Samir.
[email protected]
Aug 20, 2008 | BenQ FP71G 17" LCD Monitor
Re: FP71G+
If it's a 71g+ it should be under warranty,Benq offers 3 year warranty.Contact Benq.
Samir
May 05, 2008 | BenQ FP71G 17" LCD Monitor
Benq screen shuts down when pc is plugged in
If it's a 71g and not 71g+ resolder transistors 2sc5707 on invertor board along with grey condensers and inverter transformer.This should solve the problem if it was display shutting off with power led remaining on.Otherwise check power section.
Feb 24, 2008 | BenQ FP71G 17" LCD Monitor
Monitor goes blank
Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 16, 2006 | Dell E153FPc 15" TFT LCD Flat Panel...
BenQ FP71G 17" LCD Monitor Logo
382 people viewed this question
Top BenQ Computers & Internet Experts
Ekse
Tommmix
Level 1 Expert
Joaquim Martins
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
