Question about Dacor Preference SGM365 Gas Cooktop
Dacor range top won't stop clicking/sparking
My dacor range top's ignitors won't quit sparking afterI cleaned it. I know if they get wet that will cause it. But I've dried them well and turned on the burners to help dry them out, which has worked in the past. I will tell you that it quit clicking/sparking when the one burner was on. But after turning them off it started back up. This has never happened before. What might I be missing
  • Dacor Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Jul 25, 2010
After cleaning one of the small burners will spark
make sure the little hole right by the ignitor isn't plugged.
Jun 15, 2010 | Dacor Preference SGM365SS Gas Cooktop
Ignitors clicking
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 15, 2010 | Dacor Preference SGM365SS Gas Cooktop
Viking Burners keep on clicking! Anoying!
The causes to the clicking is that the ignitors could be wet, dirty (with grease caked on them or cleaning products or a bad spark module). The ignitors are the little white things on the side of each burner with a metal piece on top. If they are wet (let them dry out for 20 - 30 min on a high flame, if dirty sand the metal piece on top with sand paper or nail file. And if it is the spark module and u are technical, order one from the parts department for Viking. You will need ur model and serial # then find out if it is located under the burners or the rear of the range. There are several wires going to the spark module. Best way is to disconnect one by one and connecting it to the new box until all wires are switched from old to new module. Remember to unplug the unit before doing this because you may get shocked. Also if it is a sealed burner system that means that the burner bowls cannot be lifted from the range and water cannot seap under the burners then you could just change all 4 or six burner bases. Viking has adapted them throughout the many complaints and they are better now. Typical cost is: $350 - $400 if spark module is under burners, in rear = $500 - $600. Burner bases = 400 - 600 depending on number of burners and if it is with a venturi or screws. Good luck.
Aug 23, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Ignitor sparks continuously
Hi, How long ago did you get the ignitors wet? Most cases, unplug the range for a few hours giving it time to dry out. Maybe set a fan near the range top to help dry it. This helps MOST of the time. please let me know if it helps or if I can assist you further.
Vic
Jul 04, 2009 | Cooktops
Our Dacor gas cooktop igniter won't click. When I turn on the burner, you can hear the gas coming out, but no click so the burner won't lite.
Go to RepairClinic.com and check on how much a new igniter is. Is there two or 4 igniters on your model (lift the top of the range up and it is the little silver piece sticking out with a white base around it), If its 2 is the other side working? Make sure there is no food deposits around where the gas and the spark meet.
May 01, 2009 | Cooktops
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Gas ignitors continue to spark every 5 seconds in off position
try unplugging the unit over night, itspossible that by you cleaning the tops, the electrodes got wet, falsley sparkin, when the water dries out it should stop, and no not dangerous in any way, only annoying to listen to
Feb 13, 2009 | Amana AKS3040 Gas Cooktop
DCS range igniter won't stop
Hey all ... I just had a repairman fix my DCS cooktop that was doing the same thing ... ignitor problem. He replaced it and it's good as new. (Cleaning also did NOT work for me.) It cost me $216 for the repair. If you can find the part, it's pretty easy to replace. Just take off the front knobs (be careful as there is a 'ring' inside the neck of the knob) and unscrew the front. You will need a special screwdriver - looks like a star - but just snip the plastic straps holding the original ignitor in place and put the new one on the same way as the old one. You should be good as new. REMEMBER TO TURN OFF THE BREAKER!!! I can't imagine it would take more than an hour (tops) 'cause it looked pretty easy.
Sep 01, 2008 | Cooktops
Dacor gas range igniter clicking
I did have the same problem after the house keeping people done with cleaning. They used window/surface cleaner. First I asked them not to clean the ignitor with any cleaner. Here is what I did to solve the problem
I took scotch scour pad (one that you use for washing dishes), In dry state I polished ignitor switch. It is abrading the residuals and deposits on the top and polishing it. Don't use any thing more abrasive than that. MAGIC - I don't have any more problem.
Aug 14, 2007 | Dacor Preference SGM365SS Gas Cooktop
Dacor Preference SGM365 Gas Cooktop Logo
4,507 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
