Question about Sony KP-46WT510 46" Rear Projection HDTV
The screen won't turn on.
When you press the power button, it will click and you will hear sound, but that sorta staticy sound that happens before the screen turns on doesn't happen. If you continue to turn off and on for awhile eventually the screen will make the staticy noise and turn on.
  • 21 Answers
High Voltage transformer and related circuitry has fatigued or gone bad. Not an expensive repair..TV it salvagable. HV transistor or the transistor or both.. Baybe a couple of capacitors. Needs servicing. Should troubleshoot before ordering parts.
Trace Electronics Repair, Barrie, ON
Posted on May 29, 2010
1990 panasonic tv model# CTM-2783S won't turn on
the tv need for servicing, the cause is either bad regulator transistor in the power supply section or shorted horizontal output transistor. that is why the main circuit board doesn't get to turn on. to do the repair just ensure you have knowledge in repairing tv.
Nov 17, 2012 | Televison & Video
PCV R44G, won't boot, no fans, won' turn on.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 22, 2012 | Sony Computers & Internet
My sony vaio won't turn on
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
Pc turning off
Be more specific. Turning off when? What happens when you try to turn it on? When you have the power cord plugged in do you see any lights? When you press the power button do you hear the fan running, hear the hard drive running, see anything on the lcd screen, hear the cd drive Click once, see the light on the cd drive drawer turn on for a second or two when it clicks, hear any beeps or blinking lights?
Mar 21, 2012 | IBM Lenovo ThinkPad X40 Notebook
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
Compaq CQ4010F Desktop PC won't turn on after a power surge
You probably and lets hope so, have an Electro Static Charge Buildup on your desktop. Remove the Power Cord and Press and Hold the Power Button for 30 seconds. After 30 Seconds plug the Power Cord back in the hit the Power Button. If it boots then you had an Static Charge Buildup. If it does not boot and you say it happened after a power surge then either your Power Supply or Motherboard is possibly damaged. Do you hear fans, hear the disk drive running, see lights, hear the CD Rom click once and see the light on the CD Rom drive com on briefly after you hit the Power Button. If so it would seem that your power supply is ok.
Mar 18, 2012 | Compaq CQ4010F Desktop PC (NY650AAABA)
Black screen no cursor no keyboard use
When you powered on the machine did you hear any beeps, hear the fan running, the disk drive running, lights blinking, hear the cd drive click, see the light on the cd drive door for a second or two when it clicks? If these things are happening you are getting power. If not, your problem might be with your power supply, hard drive or motherboard. Remove the power cord, then press and hold the power button for 30 seconds, then plug it back in and press the power button. if it boots you had a static charge. If you get nothing at all but a silent system your power supply is bad. If it sounds like your computer is running but you can't see anything on the screen you might have a problem with your screen or video card. If you have another monitor try using it and see what happens. if it works so you can see things then your monitor was bad. If it does not work with another monitor but you still hear fans, and see lights and hear the disk drive spinning, then your video card is probably bad.
Mar 17, 2012 | Gateway Computers & Internet
My Iphone 3g doesnt turn on.. I only get the apple when powering up and then a black screen.. I tried charging it all night (different chargers) and doesnt work.. I tried rebooting many times.. that doesnt...
If you just see an apple logo or your phone does not turn on, there is a software problem and you will need to restore your iPhone. I didn't want to hear it, because now I had to redo everything; but it's the only solution.
Put your iPhone into recovery mode.
To put your iPhone in recovery mode:
Step 1: Plug in your iPhone to your computer, make sure your sound is turned on and not muted.
Step 2: Hold the top corner button for two seconds. You should hear a sound.
Step 3: Now, still holding the top power button, immediately press the home button and hold both buttons for 10 seconds. You should hear another sound from your computer.
Step 4: Release the power button but *continue holding the home button*, for another 30 seconds.
Step 5: Meanwhile, continue holding the Home button and open iTunes. Wait for it to tell you that it’s in restore mode. You should also hear a third sound from your computer during this time.
Step 6: Click on your iPhone in iTunes. It should say it's in recovery mode and need to be restored. Step 7: Click OK and restore it.
Now you will need to re-jailbreak it, and restore your backup, and also put your music back in.
Good Luck!
3ONO
Email : xxxxx_2079@yahoo.com
Dec 08, 2009 | Apple iPhone Smartphone
NO OUTput
Check To See If The Cords Are In Your Tv And Are Fully In Not Just Sorta In And Check To See If They Are In The Back Of Your Ps3 Fully And Make Sure You Are On The Right Channel
Jun 27, 2009 | Sony Playstation 3 (PS3) Console
Sony KP-46WT510 46" Rear Projection HDTV Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
