Question about Gateway MX6453 Notebook
Hello, my laptop runs then will cut off after about 30-45 minutes?
    Problem Solver:
  • 12 Answers
Mine use to do that try buying a house fan and sitting next to it
Posted on May 30, 2010
2006 nissan xterra code p1000
Means it hasn't completed a driveability cycle. I ignore it. But I live in a non inspection state. If you need it cleared. Then you have to look at the readiness state of the sensors. See what failed. Takes a scanner. Also, you can get past the code with a scanner in about an hour. Otherwise it could take up to a month with regular driving. Part of the procedure is. Driving in stop and go traffic. Driving at 30,45, and 60 MPH for so many minutes. Scanner tells you what to do.
Aug 06, 2016 | 2006 Nissan Xterra S
My AC unit runs for 15 minutes the cuts off. Then there is no
Hello, if there is a condensate safety switch this will cut off power to the tstat if the comdensate line is backed up. Check the condensate line to make sure it is clear.
May 06, 2012 | Heating & Cooling
Starts then cuts off and won't restart
Hello; This is likely a carb problem or clogged fuel line or fuel filter if it has one. If it runs for awhile before cutting out, check your gas cap. They all have some sort of vent to let in air as the fuel level goes down. If the vent is clogged, the carb can only **** out the gas for seconds or a few minutes. john
Aug 15, 2011 | Poulan Garden
I have a cookwell steamer and want to steam some sweet potato but dont know what intensity and how long to steam it for
I also enjoy sweet potatoes very much. My rule of thumb is steam until fork tender.
For whole sweet potatoes, I suggest 20 minutes minimum and checking every 10 minutes unitl fork tender, medium setting.
For cut up sweet potatoes, I would think it would be done in 8-12 minutes depending on the cut size.
Just make sure the steamer doesn't run out of water. I would also suggest grilling sweet potatoes (delicious!).
I hope this helps. Please rate my solution.
~PCF
Mar 09, 2011 | Vacuums
Im having a problem keeping the motor running. it cuts off and will re-start easily and run in the choke mode? won't run in the normal mode until i cut it off and re-start. then it will run for about 5...
Hello. Your carburator is gummed up. Get a can of seafoam fuel additive at the auto parts store and put the recommended amount into the gas. This will clear up the problem in just a few minutes. Joe
Mar 16, 2010 | Northstar Pressure Washer 3000 PSI
Washer Dryer Combo cuts off after running for a few minutes...???
hello. if your washer is 120 volts, it must be plugged into a 120 volt outlet.
Oct 01, 2009 | 2002 Jeep Grand Cherokee
Runs about 10 minutes 7 cuts off. can't restart
Plan your beer breaks every 10 minutes and enjoy the time off. Also check your fuel mix, the engine is running hot, replace fuel mixture with proper oil mix.
Jul 15, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Toshiba laptop U205-S5002 takes a long time to start up.
You can check this by going to start, run, type msconfig and checking the startup tab. this will show all of the programs that run at startup. just uncheck all that are not vital.
Jan 27, 2009 | Computers & Internet
Dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Oct 19, 2008 | Magic Chef CYG4000AWW Gas Dryer
Gateway MX6453 Notebook Logo
27 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
