Attempted to burn a DVD
I have recorded a movie onto the Hdd of my Lg rh7500 dvd recorder and attempted to burn a DVD but I got a message says ''change the recordable disc '' I have tryed several type of discs with the same message appearing, what am I doing wrong?
  • 313 Answers
The lens for reader is a common issue and causes those errors. Get inside the box, take off the two screws on the DVD drive cover and (delicately) remove dust from the lens and surroundings. You should use delicate brushes and air blast, but I got some soft tissue and gently wiped.
I hope this helps
Posted on May 29, 2010
I have recordered many home movies to a dvd+r
Dvd+r disks are the least compatible to most devices.
Try using Dvd-r instead.
Dec 02, 2009 | LG RH1999H DVD Recorder/HDD Recorder
My LG DVD RECORDER, MODEL RH7500 won't play DVDs.
Check the model specifications for your device. Some players will only accept DVD-R and not DVD+R or not DVD+RW discs. I know it all seems the same, and it's very frustrating, but many companies restrict the type of discs they will allow. My player does +R but not -R. It should still be able to read DVD discs that you made yourself, but they will be of a different type.
Nov 03, 2009 | Televison & Video
Will play discs burned from hdd but not commercial movie type dvd
The solution is simple.I rang LG service (so called - LOL)
Asked for a fix or reset method. (Which can be done but they won't tell novices how)
Got no joy, so now I will bin it,and spend the rest of my days telling people to avoid LG.
After all the posts I have since read about the same problem on various LG models,it is obvious their product sucks,they know it does, but won't accept the responsibility.
If I stop 4 people buying their ****,that's at least $1000 they miss out on.
If the process snowballs,how much then$$ ?
It would cost me $120 just to get it to and pick it up from the repair place.
Plus parts and labour added.
Before buying an LG DVD recorder go online and check out how many dissatisfied customers there are. In short, DO NOT BUY !!
Jul 18, 2009 | LG RH266 Recorder
Unable to record e.g MOVIE from TV to DVD disc
Just record the shows to the hdd and when your there then burn the shows into the dvd from the hdd.the dvd is pretty small it wont hold many shows.
Apr 27, 2009 | Televison & Video
I have a hdd/dvd recorder model rh7880/rh7500 set timer recording to record onto dvd, machine switched itself on as normal but did not start to record and froze up.cannot get anything to respond either...
Recorder wasn't under warranty, so opened the unit up removed the dvd - rw disc ,which was corrupted as it turns out, put the machine back together switched it on and it worked perfectly.I have since tested it by recording both on to dvd,hdd and used the dubbing format and have had no problems.In the future I would recommend bying only top quality discs as it seems a dodgy one was responsible.
Jun 29, 2008 | LG Televison & Video
I have a lg dvd recorder model RH7823W. I have recorded something onto HDD and i want to burn it onto a DVD.
If you read the instructions, it's under "Dubbing" - Page 51. The one thing the printed manual fails to tell you is that you need to "finalise" the disc if you want to play it on any other player apart from another RH7823W - DOH! See page 23.
Mar 11, 2008 | LG DBRH197H DVD Player/HDD Recorder
DVD Burning doesn't work..no Disc in Setup..
Been checking out my m/c and found that there are many -r & -rw discs the m/c does not recognise which gives rise to this problem. However the m/c does recognise VERBATIM discs and I have been able to record and dub to them with no problems.
Jan 22, 2008 | LG RH-4820 DVD Recorder
I cant record DVD's
If you mean burn a movie from the HDD to a DVD. It will only let you do this once.
Dec 30, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
