Question about HP DeskJet 5850 InkJet Printer
The top hold down for my black cartridge broke. Where can I get repair parts for my 5850?
  • 973 Answers
Go to www.hp.com ,
Posted on May 29, 2010
I dont know how to get into printer to change the ink cartridge hp deskjet 5850
Do this to change the cartride.
1 - Switch the printer on.
2 - Open the front cover by raising the black lid upwards.
3 - Wait a while and the print cradle will move to the right and will become idle and quiet.
4 - Press down on the cartridge to be replaced and slide it out.
5 - Remove the new cartridge from its packaging and remove the safety tape - dont touch the copper parts.
6 - Slide the new cartridge in, use a slight angle, and press until you hear a click.
7 - Close the lid.
8 The printer may print a test page
Apr 26, 2010 | HP Office Equipment & Supplies
HP 5850 Top Cover Open error message
There is a sensor that tells if the cover is open or closed, and a plactic "tongue" protruding on the cover, usually near the hinge, that goes into a recess in the printer.
Two things may have happened - this "tongue" broke off at some point, or the sensor developed a fault.
There are optical sensors, where the "tongue" blocks light going in between an emitter and a receiver, and simpe electrical contact sensors, which open or short when the "tongue" goes up.
There's not much that can be done with an optical sensor, but an electrical one can be inspected and corrected if needed, if you have some manual skills.
Dec 30, 2009 | HP DeskJet 5850 InkJet Printer
The cover that locks the black ink cartridge in
THE ROLLER THAT HOLDS THE PAPER MIGHT NOT BE HOLDING IT TIGHT AND FOR INK CARTRIDGE IT IS AN EASY FIX YOU CAN SURELY DO THAT YOU JUST NEED TO GET AND HOLD OF THE TECH AND ASK FOR THE PART.
Oct 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I have a stuck power button on an HP 5850. It is
Try using a needle to pop the button back up. If this fails then most likely the spring for the button has failed and you'll have to use your new parts. Another method is to tap the button with a teaspoon handle lightly several times.
Sep 21, 2009 | HP DeskJet 5850 InkJet Printer
Can I replace the PSC2210 print cartridge hold down lever?
The entire unit which holds the cartridge needs to be replaced. get it dont by some local tech shop.
Thanks
Nov 26, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP 5850 IInkjet printer. The print cartridge hold down cover for the hp 56/hp 58 cartridges is cracked and will not last long.
IT would be hard to find this part......but easier way to fix this problem is to do a plastic solder
Get a small piece of hard plastic....
Heat up your soldering iron....
Put the small piece of plastic as where the crack is and melt it down on the crack using the hot solder..
evenly press down this hard plastic over the cracks.... with the solder for neatness and for toughness
you can even put in a few staple pins bent across the crack and melt it in the plastic for more stronger bond
the wider the area you use the stronger it will be...
Do a few off hand practice for perfection
Hope this was of help
Cheers!
Nov 11, 2008 | HP Office Equipment & Supplies
Latch door that holds ink cartridge in place
Good luck on finding somewhere that will sell you this part. I had one that did this and I used tape to hold it together. You might watch ebay and see if one comes up cheap for parts.
Mar 27, 2007 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5850 InkJet Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
