Question about Acer Aspire 3680 Laptop
I can't reboot after installing Intel VGA driver
Hi! i got a problem after installing Intel VGA driver v7.14101132. This application has failed to start because MSVCP71.dll was not found. It says re-installing the application may fix this problem.
My desktop is also not accessible. It says "Insufficient system resources exist to complete the requested service"
Would you help me resolve my problem please.
Thanks in advance!
Just try to run in the safe mode 1st and try to fix the problem there.Your video card most probably is a built in with the motherboard and the new video card driver might require you a higher memory.
1.The idea is to restore your original video card driver
2.If your running xp or windows 2000 press F8 to check your sysytem and boot in safe mode.
e-mail me at
good luck
Posted on Apr 08, 2008
I have a acer desktop computer. model no is-R14-A2C0, and problem is i have no vga driver, so i want vga driver for that.
You can reinstall the VGS drivers from the Acer recovery management, to do so:
Start Menu> All Programs> Acer erecovery management> Restore> Restore Application & Drivers> Contents> Select VGA (ATI or Intel) and install it
Got to
Select the computer model
Select Operating System installed on your computer
Click Drivers
Select ATI or Intel and download it.
Once downloaded, install it on your computer.
Thanks and regards,
Feb 07, 2011 | Acer Intel VGA
What graphics adapter upgrade do I need to make
The graphic adapter is the video card installed inside the laptop, and normally does not get replaced, as this is integrated with the motherboard.
After installing Windows 7 you will need to install all drivers.
I would recommend using Vista on this laptop, since factory drivers for Windows 7 had not been released. You will have to install general drivers not designed for this laptop.
If you want to install Windows 7 here you get the instructions.
I quote the part concerning video adapter drivers:
"Update the Video Driver
  1. Preparation
    1. Be sure there are no other video drivers installed (you will want to start out with just the standard VGA driver)
    2. Download the latest 82852/82855 drivers from Intel's website
    3. Extract the drivers somewhere, but do not install anything
  2. Turn Off the Digital Driver Signing Check
    1. Create a shortcut on the desktop to cmd.exe
    2. Right-click on the shortcut and select "Run as administrator"
    3. When the command window opens, execute the following commands:
      1. bcdedit /set nointegritychecks ON
      2. bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS
    4. Reboot
  3. Install the Video Driver
    1. Open the Device Manager
    2. On the menu, go to Action > Add Legacy Hardware
    3. Acknowledge the initial dialog screen
    4. Select "Install the hardware that I manually select from a list (Advanced)"
    5. Click Next
    6. Select "Display Adapters" and click Next
    7. Click the "Have Disk..." button
    8. Navigate to the path where you extracted the Intel drivers. The *.inf file will be in the Win2000 folder
    9. IMPORTANT: Do not select the 82852/82855 GM/GME drivers, select the 945GM driver (yes, this is counter-intuitive)
    10. If prompted to reboot, DO NOT REBOOT
    11. If told the 945 device might not work right, acknowlege the error, then run Action > Scan for Hardware Changes
    12. "Intel(R) 82852/82855 GM/GME Graphics Controllers" and a "Mobile Intel(R) 945GM Express Chipset Family" devices should now be listed under "Display Adapers
    13. Disable the 945GM device
    14. Reboot
  4. Verify the Video Driver Installation
    1. Upon rebooting, Windows 7 may roll back one or more of your display devices to Standard VGA
    2. Open Device Manager
    3. Check the Display Adapters
    4. If there is only one 82852/82855 GM/GME device, or if there is a new "unknown" device, precisely repeat the above driver installation section (include the instructions for disabling the 945GM device); in the case of an unknown device, run the "Update Driver" action for that device instead of running the generic "Add Legacy Hardware"
    5. When everything is working, you should have "Graphics Properties" and "Graphics Options" menu items in the pop-up menu when you right-click on the desktop
    6. The "Graphics Option" item should have sub-items for display rotation
    7. Reboot and verify that Windows 7 no longer rolls back your display drivers after rebooting
  5. Protect the Video Driver Installation
    1. Go to Control Panel > System and Security > Windows Update
    2. Windows will likely tell you that an important update is available
    3. Click the "important update is available" link (do NOT click "Install updates")
    4. Right-click on the "Intel Corporation - Display - Mobile Intel(R) 945 Express Chipset Family" update
    5. Click "Hide update" from the context menu
    6. If the display driver gets updated to what is currently on Windows Update, the system will revert back to the Standard VGA driver.
  6. NOTE: When using a driver install hack different from the method described here, I have read reports that a system might Blue Screen when using Windows Media Player to play DVD's; however, alternate media players, such as VLC, reportedly do not exhibit this issue. I do not know if this method will have this same problem, but I thought I would mention this workaround in case someone does experience this issue."
You find driver software at Intel Download Center
Oct 26, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
GeForce 8500 on Intel DG35EC no display
Make sure the card is seated all the way in the slot. And the slot is clean, also check the power plug if it has one.
Aug 23, 2009 | ASUS GeForce 8500GT Graphic Card
Lost the drivers CD for i-d946gz, need to format the sysm: how?? how to download the requisite drivers and applications
try here
Jun 12, 2009 | Intel Computers & Internet
Please send me VGA driver for pentium 4
Hii, you can download all the driver of your Intel motherboard including VGA driver also from
Go this site and at the left hand side, go to the desktop board andselect your exact motherboard model. After selecting the model you justdownload the driver as per your requirement and install it.
Mar 02, 2009 | Intel Celeron -D 2.26Ghz Computer System...
Icant install vga drivers for my pc i have the problem display
go to start
than run
type in msconfig
and disable all services and starts
press ok
install ur vga driver
when it says u need to reboot prior vga driver than dont
go again in msconfig
enable all what u have disabled and press ok than reboot
when ur system start the vga driver is loaded in the services and wil work properly
if this wil not work than there is a program in the background that u wont let the vga driver install
than u go again in the msconfig and there u disable one by one the servicers and starts
that means disable the hook in the tab press ok and reboot and try to install the vga driver
its a long process but so u will find the software thats blocking ur install
Jan 04, 2009 | Intel Gigabyte 8I845GVM-RZ 82845GV GMCH...
VGA driver for toshiba A135-S4527
Hi! I have some problem with my Toshiba A135-S4527 vga driver. I have a disc driver. But its vga driver has expired. So I need to have other one to solve it. Thank for you aide :-)
Dec 27, 2007 | Toshiba Satellite A135-S2276 Notebook
Acer Aspire 3680 Laptop Logo
93 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
