Question about Sanyo 18KS52 Air Conditioner
We have a leakage of water when the unit is run.
Remove the cover and in the right hand corner is where the drain trap is usually located the can become plugged with a scummy like substance from the condensation or if you go to wherever the end of the drain from the unit is located you can actually blow through the drain an d remove most plugs
Posted on May 29, 2010
What corrective action for an le code?
The le error code means the leakage sensor located in the middle of the base has detected water. Check asap to see if there is water leakage underneath the unit. The sensor must be dry in order for the error to be cleared. Usually, when these sensors are active, they will tell the main board which will not allow anything to run until the code is clear--for obvious reasons.
Aug 11, 2015 | Samsung Dishwashers
What causes a Samsung dishwasher to flash heavy and smart auto on control panel
Hello. The lights you describe are an error code that means over-level filling (overflow condition) and/or the leakage sensor underneath has detected water. You need to check underneath the unit for any moisture. There is a leakage sensor located at the center of the base, underneath the unit. If it detects water, it will notify the main board which will stop the unit until the condition is cleared.
Aug 02, 2015 | Samsung Dishwashers
Water leakage
Your not to clear about your problem. First I need more information. Is it a window unit, or through the wall or a split unit???
Usually when there is water leakage from a window or through the wall unit there could be one of two problems. One being a clogged area in the condensate pan not allowing the condensed water to flow out of the back of the uinit, or two, the unit is not properly tilted outward to allow the water to flow outside.
If it is a split unit and it was previously working fine then it most likely is stuffed with debris and should be cleaned out.
Good luck, I hope I have helped.
Marty
Apr 04, 2014 | Whirlpool Heating & Cooling
Heavy light flashing
Heavy Light flashing indicates leakage error.
The leakage sensor on the bottom cover of the unit is detecting water in the bottom of the dishwasher. Possible parts that could be the issue are as follows: Hose Connections, sump and tub assembly, drain pump or just simply the main PCB.
tip the unit in its back and remove the bottom cover. disconnect the leakage sensor and inspect the inside of the unit carefully for ANY water leaks. Most of the time its a mouse chewing holes in the tubing for water. Otherwise check carefully and you will see the leak.
Mar 23, 2014 | Samsung DW80F600 24" Black Built-In...
Error code e15
The E15 error message specifically indicates that there is a flood issue on the unit. This usually happens when the bottom part of the unit becomes flooded with water.
STEP 2
If this happens, there is a possibility of a leakage somewhere in the system. This occurs mostly on the drainage system of the unit where the water passes through different hoses pipes before finally releasing the water to the sewage. STEP 3
This problem can be solved by inspection. Remove the unit and take off the cover. Drain all the water and look for the source of the leakage.
Mar 04, 2014 | Bosch SGE63E15UC 24 In. Stainless Steel...
The indoor unit of my 1.5 T , 2 yr old split ac is making noise like cracking of ice or plastic whenever the compressor is tripped or restarted. I've noticed water leakage (splash) from indoor un
indicates dirty evaporator fins that are icing up
that will overload the compressor and trip it
the ni oise you hear is the ice breaking up and the splashing is excessive water in the blocked drain that cannot run outside
get in a technician to clean and service the ac
Nov 24, 2017 | Heating & Cooling
Hear water running through unit.
If you hear water but dont see any leakage what your very likely hearing is the water from the melted frost of the defrost cycle,that is a normal sound that you will hear from time to time and its a great sign that everything is working exactly as it's supposed to.
GENE
Aug 28, 2011 | KitchenAid Superba® Architect® KSRP22FSMS...
Water left in dishwasher after all cycles completed.
Please check the outlet hose which is usually connected to the garbage disposal unit beneath the sink. Run the garbage disposal unit with water flowing through the sink. If this doesn't help you will have to unclog the outlet hose by either disconnecting the the end connected to the disposal unit (keep a shallow tray handy to collect any leakage).
Sep 25, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Split ac not cooling
cak split in door unit 1st watar lavel and in sait watar tra blok paip.
Apr 07, 2009 | LG Heating & Cooling
Split System Air conditioner
There normally two types of leakages from the wall unit.
1.The warm air in the room when comes in contact with the cooling coil of heat exchanger (consisting of fine fins where compressed refrigerant evaporates) looses its heat & cannot retain the same moisture content at lower temperature at the point of contact with evaporator. There is a provision of a drain pipe to carry this condensed water to outside water drain. So if the drain pipe is choked or the coupling joint of the drain pipe at the bottom of cooling coil is not proper, there will be water leakage, This can be easily attended by physically looking at the fittings.
2.The second problem can be the leakage of the refrigerant. If there is second type of problem, then there will be very little or no cooling irrespective of continuous running of air conditioner. This can be easily checked by feeling the temperature of outlet air from the air conditioner.
Conclusion-As you have written that there is leakage from the air conditioner, but you have not written whether it is visible or invisible. If the leakage is visible, it is problem number 1 & if it is invisible, it is problem number 2.
If you are not satisfied you are free to ask for more explanations.
Jan 29, 2008 | Heating & Cooling
Sanyo 18KS52 Air Conditioner Logo
146 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
