Question about Galaxy Radios DX-44V 40-Channels Base CB Radio
I try to fix northstar dx 440v , when i press the mic is sound pi pi pi pi and the modu lation is moving to the high can i have the solution? impact3508@aol.com
  • impact3508 May 29, 2010
    I tryed that already and it only does it on AM, radio works perfect on Fm dont know why? Any thoughts?
    Genius:
  • 1,274 Answers
Try turning the mike gain down..- minimum to half on the mic Dial. now key-up and get a radio check, and ask them how it sounds...hope this was helpful..
Posted on May 29, 2010
"fujitsu amilo pi 2540 built in mic not working"
Please check the settings under the Control Panel's Audio or Sounds.
Feb 27, 2014 | Computers & Internet
Sound is lost and regain when mic button is pressed
i would assume you have wired it incorrectly or have tried another 4 pin mic such as an midland which are wire differently for the galaxy, ranger, connex, cobra an undien 4 pin mics. Galaxy Radios DX959 MOSFET Final Service Manual
Aug 01, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
Why does the sound come back on when I press the mic on my galaxy 959
bad ground to antenna Check your SWR with a voltmeter and a swr meter.check everything, check your mic connection for broken wires try another mic.
Cobra 19 DX IV stuck on busy no matter what i turn or press. even pressing PA doesnt swith it to PA.
check the mics wiring if the mic is not right on some cbs the sound goes off
Jun 18, 2012 | Cobra 19 DX IV CB Radio
Galaxy DX 98VHP meter stopped moving . There is no swr reading, nothing. Even with a seperatye meter atached or a dummy load, the meter on the galxy is not working. Did I lose all power?
You appear to be aware of you antenna system with the separate meter attached so the tells me you dont punish a radio with an high swr. I am just guessing red wire/solder in mic cord at plug given that it is a side mic mic jack.
Stock mic
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Jul 02, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
I have a uniden grant and i have wired a galaxy power desk mic with rogger beep when ever i key it up it squeals was wondering is there a way to fix that
yeah your mic gain is way too high. You can either turn off talk back if you can, or turn the gain down. Depending on how loud the talk back is, your audio may suffer. If that is the case, you will not be able to run that mic. Get an RK-56 or a Skythumper mic. They are noise canceling. You will get no squeal with that mic, and it will sound awesome.
If you really want a roger beep, take it to a tech and them install one.
Oct 23, 2010 | Galaxy Radios DX-66V Base CB Radio
How to calculate a finite integral
Press 2ND MATH to bring up the Math menu. Select "Calculus" and then "integrate." Enter the expression, the variable of integration, the lower limit, and the upper limit, separated by commas. Close the final paren and press ENTER or diamond ENTER.
For example, to calculate the integral from 0 to pi of sin(x) dx, you want
INT(sin(x),x,0,pi)
where INT is the integral sign and pi is the lower-case Greek pi.
Sep 22, 2010 | Texas Instruments TI-89 Calculator
I have a corba 148 gtl when you key it moves no audio
Sounds Like you have Bad wiring in your Mic connection. Also if you are using it at home on a power supply make sure its regulated so to not get the Humming sound. Also what type of Coax Cable and antenna are you using? Also are you using it at home or in the Car? Have you tried a different Microphone? Hope this Helps. Let me Know.........
Jul 04, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Nintendogs
If you have any other game that uses a mic, you should try those to see if they work. If those work, it can't be your mic, it has to be something with the game.
Oct 26, 2008 | Nintendo DS Lite Console
Galaxy Radios DX-44V 40-Channels Base CB Radio Logo
252 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
