Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Replacing fridge water filter and pressure builds up, but no water comes out
  • 652 Answers
You need to check your line to see if something is clogging the line. Check the source of the water line to the fridge. If this is fine you may need to run air with a air compressor through the fridge lines. unhook the line in on the back make sure you turn the water source off before you disconnect the line. Have someone stand in front of fridge to push the water as you pressure the fridge line with air, this should unclog it or you can call sears they will come out to your house and repair any brand.www.searshomeservices.com/
Posted on May 29, 2010
  • toddcampbell May 29, 2010
    There is water going to the filter, and the ice maker worked until last night. Now I go to change the filter, pressure builds up and pretty much blows the filter off when you release it. So you think the line from the filter to the dispenser might be pugged?
Ge gss25pgmf
Before replacing water valve open open back panel disconnected water line of water dispensser and tell some 1 to press water actuator on dispensor and check water pressure from it. If its slow then it can be valve or it can be filter housing. Repalce both if confuse.
Mar 03, 2014 | General Refrigerators
I have a Maytag Model #PSD262LHEB refrigerator and the water comes out well and then it makes a purr noise and starts coming out very slow and thin. I've changed the filter as per the Manual and nothing. ...
1) Can you turn up the water pressure with a valve that might control the water connected to the fridge?
2) If there is a plastic water supply tube in back of the fridge you may want to disconnect it and see if there is ample water going through or try replacing it to see if it may be the problem.
Dec 25, 2013 | Maytag Refrigerators
Electrolux EW28BS71IS French Door Fridge no water and no ice
First check that you have good water pressure to the water valve. If you do, then the problem is in your refrigerator. And the most likely fault is the solenoid controled water valve which is a one in two out valve. Follow the water line from you house input and the first place it connects is that valve.
Jan 10, 2012 | Electrolux Refrigerators
Does water supply need to be shut off to change water filter on model 106 side-by-side fridge?
no,the solenoid valve will keep it closed as long as you dont activate any controls while the filters off
Sep 08, 2010 | Kenmore Refrigerators
My Frigidaire side-by-side leaks inside, from water filter
the gasket that holds the water pressure in between the water inlet line and filter is not in proper position, or your filter sir is nt properly inserted into the slot,the cycle starts when the water comes in,pressure will build up and it will start t pass in between the gap, as the pressure goes down, dripping will stop, then cycle start again, check the connector sirandhose connected into the filter
Mar 18, 2010 | Amana ACD2232HR Side by Side Refrigerator
Water dispenses very slowly on Fridge
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The coil of tubing is normal so you can move the fridge out from the wall without damaging anything.
Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 14, 2010 | Refrigerators
Side-By-Side GE Fridge Won't Supply Water
Sounds like a frozen line ... press on the inside door lisen to see if there is ice inside defrost the freezer check if water will flow ... if stainless steel door there is a heater kit you can put in... if plastic you will have to replace the door.
Dec 15, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Oct 05, 2007 | Admiral 26 cu. ft. Side-By-Side...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
