Question about Epson TM-T88III Thermal Printer
Ink pad full - Epson TM-T88III Thermal Printer
    Scholar:
  • 94 Answers
Try to follow this steps:
1. Long press the power button for 10 seconds.
2. While pressing the power button disconnect the power cord at the back of your printer.
3. Turned it On again then try to print.
If it can print, Every time you print just always perform that solution because your printer are meet the maximum number of copies to be print that's why the problem are back. You can also downlaod the reseter program of that printer to permanently solve that problem.
Posted on May 29, 2010
E8 Waste ink absorber full, or platen waste ink absorber full WHAT MUST DO?
I am told that this will reset your counter and eliminate the full absorber warning that you are getting.
Cleaning the pads is messy, sending the printer to Canon is expensive,
I used a simular reset code for my MP470 and haven't had any problems.
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Jan 14, 2011 | Canon PIXMA MP190 All-In-One InkJet...
WON'T PRINT - SAYS THE INK PADS ARE FULL AND NEED CLEANING.
The ink pad absorbers are full and need to be cleaned, take the top off, near the printer you will see a rectangular well with white ink pads covered in parts with ink. The pads need to be removed and put under running cold water for several minutes, next let them dry overnight on paper towels. When dry, carefully install the pads back in the well.
Jan 05, 2011 | Canon i350 InkJet Printer
Ink absorber full
There are two possible reasons for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads
. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error.
Reset the Printer using an MP Tool
Mp Tools are utilities designed to clear errors that will appear in an MP160 printer. Download this MP Tools here.
while the printer is on Run this software
1. Click Reset Main (main) to reset the waste ink counter and
2.
Click Reset Platen button (E27).
If errors still persist.
Press and Hold down Reset button and wait until the printer restart.
Release the Reset button and wait until it fully initialize.
Happy printing.
Please comeback and rate this answer.
Thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber is full cannot print
Mp Tools are utilities designed to clear errors that will appear in an MP150 printer. Download this MP Tools here.
2.
Happy printing.
Aug 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
WASTE INK ABSORBA FULL
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 23, 2009 | Canon Office Equipment & Supplies
Stopped printing after 'waste ink full message' how to I fix it.
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
May 20, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Waste absorber full
May 19, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
How do you find the waste ink collector on a printer/scanner ?
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Indicates waste ink absorber is almost full on cannon i9900 print
The waste ink absorption pads cannot be emptied, only replaced.
May 16, 2009 | Canon i9900 InkJet Photo Printer
Its appear " The ink absorber is full. Contact the service center."
May 11, 2009 | Office Equipment & Supplies
Epson TM-T88III Thermal Printer Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
