Question about Nokia 6300 Cellular Phone
My phone says Insert Sim Card. the sim card is in. i cleaned it a couple of time but still the same. I fitted another sim card in and it worked. The problem is with the sim card
    President:
  • 1,851 Answers
Right
Posted on May 29, 2010
How to insert sim card in phone? and which card insert micro sim card or full sim card?
Depends on what phone as to what size. Most phones have the sim card under the back cover....some are under the battery. A few have a small door on either side of the phone. It should be relatively obvious as to which one will fit once you see the sim port.
Jul 18, 2016 | Cell Phones
My pantech is brand new. it worked fine when i first got it but out of no where it keeps saying insert sim. my sim card is already in it. what do i do? this is the secound time this has happened.
Try removing the SIM card and clean the contacts on the SIM card and the cell phone with ethyl alcohol, then replace the SIM card. This will make sure the SIM card makes proper electrical contact.
If this does not work the the SIM card may be faulty, you need to contact your cell phone provider for a replacement SIM card.
Aug 26, 2011 | Cell Phones
My phone is displaying insert sim card even if i fit the sim card correctly
Try removing the sim card then cleaning the golden plated are on it. You can also clean the area where you place the sim card in your phone just in case. Afterwards just place it back in and try turning on your phone.
Jun 13, 2011 | Cell Phones
My phone said to insert sim but ive inserted my sim and tried to take it out and insert it again it still say insert sim
Here's what you have to do.
Maybe your sim card is not well fitted on your sim card port. If you thinks it is well firtted, based from my experience, just insert your sim card as usual to the sim card port and then do that 5 times. (rubbing slowly). and then try to power it on. Just try it. Hope it will work for you..
Nov 29, 2010 | Sony Ericsson Walkman W705 Cell Phone
Sim card
How to correct sim card error / insert sim card
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it
Step 2: If the sim seater/tray is not broken, clean the entire terminal.
Step 3: If the sim seater/tray is not directly on the board, trace the broken led and solder it, or you replace the broken led with another sim tray.
Step 4: If it is still not working, change the battery and put a new battery, because a virus infected battery will always give such problem.
Step 5: Finally, if the problem still persist, then check the sim card and replace with another sim card if the former is bad because a bad sim card will always display such message as insert sim card or sim card error.
Take care
Apr 13, 2010 | O2 Samsung SGH-E250 Cellular Phone
Turn on the phone and it says insert sim card with the sim card installed.
Take the sim card out and make sure that it is not bent. Then clean the gold part by rubbing it on your shirt to make sure that there is no dust on it. If you can reach the contacts on the phone, rub your clean finger on them a couple of times to make sure that it's clean too (compressed air is best if you have it). There is only one way that a sim card can go in properly, so make sure that you put it back in right (most phones have a picture of a sim card close to where the sim slides in as a guide). If you are sure that the sim isn't damaged and you have it in correctly, and it still doesn't work, you probably need a new one.
Jan 31, 2010 | Motorola Mobility i776 Cell Phone
Inncorrect SIM card.
  • Clean the connectors on the SIM card with a soft brush, cloth or q-tip moistened with any type of unflavoured, colourless alcohol.
  • Check whether the card is damaged or worn in any way.
If your SIM card is damaged or does not work properly after cleaning, please contact your operator to obtain a new SIM card.
Error message Insert Correct SIM
Your phone is probably SIM-locked to a specific operator's SIM card. This is usually the case when you buy the phone from an operator. SIM- locked phones may be unlocked – contact your operator for more information.
Jan 09, 2010 | Sony Ericsson K610i Cellular Phone
Insert sim
Remove the SIM and clean it with soft cloth.
Try the SIM on any other Mobile phone.
You can also try another SIM card on this mobile to make sure the phone is working properly.
If another SIM card is working properly that means the SIM card you are currently using may be corrupt. Its easy to replace a SIM then replacing a phone.
Clean both SIM and phone Connectors then try to insert the SIM.
Thank you for using Fixya.
Nov 14, 2009 | Motorola Mobility SLVR L7 Cellular Phone
I have a sony erricsson 500i cellphone, the past couple of days I have been losing service and my screen says insert sim card and the card is in already
If the display says "Insert SIM" it means that the phone has no contact with your subscription card (SIM card) in the phone. We recommend that you remove the battery and the SIM card, and clean the connectors on the SIM card and the phone with a soft brush, cloth or q-tip moistened with any type of unflavoured colourless alcohol.
At the same time check whether the card is damaged or worn in any way; if so its connector may not align with the phone connector. Please contact your operator / carrier to obtain a new SIM card. function flashView(file,alt){ var lcParam = 'et'; var ccParam = 'ee'; var flashVar = 'ciptexturl=/cws/support/phones/textandanimationdetail?cc=ee&lc=et?name='; if(ccParam == '' || lcParam == ''){ flashVar = 'ciptexturl=/cws/support/phones/textandanimationdetail?cc=ee&lc=et&name='; } var file_ext= file.substring(file.lastIndexOf('.'), file.length); var HTML = ''; flashVar = flashVar.replace(/&/g, "!"); if(file_ext.indexOf('swf') > 0){ HTML += ''; HTML += ' '; HTML += ' '; HTML += ' '; HTML += ''; HTML += ''; } else { HTML += '' + file + ''; } document.getElementById('tsflash').innerHTML = HTML; }
May 28, 2008 | Lands Phones
Insert sim card
try and make sure that you push the sim card as you put it in.
also make sure that points are connected.
Dec 23, 2007 | Nokia 6080 Cellular Phone
Nokia 6300 Cellular Phone Logo
131 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
